87 efi running rich
Old Jun 21, 2007 | 08:17 PM
cblack30907's Avatar
cblack30907
87 efi running rich
I just put a 93 gt 5.0 in my truck. I'm running the same efi that came in truck. now it running very rich. Can someone help me?
Old Jun 22, 2007 | 06:40 AM
LxMan1's Avatar
LxMan1
Check the MAP sensor and make sure that you have a good vacuum signal to it.
Old Jun 23, 2007 | 09:59 PM
cblack30907
Thanks for the reply. I got another problem that might be the cause. The high pressure fuel pump was not coming on so I jumped it at the test lead. The relay is not clicking in. Replace the relay and still nothing. Checked the wiring on the plug with a circut tester. The tan and light green wire has no contact when I turn the key on. I checked this wire to the ecc and it has no shorts. When I do on ground the test wire the truck starts run great because of the lower fuel pressure but shuts off after a minute.
Danp65
Dec 3, 2015 09:32 AM
Peavey1986
22
Jun 6, 2015 05:00 PM
peewee1986
Oct 13, 2010 08:15 AM
kameronth
1978 - 1996 Big Bronco
16
Jun 8, 2008 03:20 PM
Wilber15
May 20, 2002 05:54 AM
