Sponsored by: Real Truck
sirius problems
Old Jun 21, 2007 | 06:53 PM
GeneralC.'s Avatar
GeneralC.
sirius problems
i bought sirius satellite radio a while back and i still cant find a way to get service without the fuzziness in it. the guy at radioshack told me to unplug the antennae from the back of the radio. would this work, has anybody done this. i really dont want to spend 70 bucks on a direct connection switch. if anybody has done this could u tell me how to do it myself. thanks
2005 f250 xlt 5.4 supercab
Old Jun 21, 2007 | 06:58 PM
suzuki0702's Avatar
suzuki0702
change your fm transmitter channel, chances are you are picking up signal off another nearby radio station. if that doesnt work i suggest buying a new headunit with an input on it. i have my tv, with the aux input the sound quality is amazingly better. sounds like a cd. i really suggest the aux input route but try changing the fm channel to something out of the ordinary thats not around any fm stations! later
Old Jun 21, 2007 | 07:08 PM
Passin Thru's Avatar
Passin Thru
Ours in a Prius is fuzzy around DC and anywhere in canyons, even loses the signal through the Harpers Ferry WV area. Someone makes a better antenna w/a mag mount I hear. Lookin for it myself.
Old Jun 21, 2007 | 08:34 PM
GeneralC.'s Avatar
GeneralC.
ive already tried changing the fm frequency. i live in a pretty populated area full of radio stations
Old Jun 21, 2007 | 08:38 PM
harstad23's Avatar
harstad23
Your best bet is to get a direct connection. You will be happier and your radio will sound a whole lot better. Yeah, its another $70 bucks but it will save a whole lot of trouble and pain.
Old Jun 21, 2007 | 08:44 PM
CounterMaker's Avatar
CounterMaker
definatley a direct connection....you will get some fuzzyness if you dont...i took my sirius out because i didnt want a direct connection and i never looked back....
Old Jun 21, 2007 | 08:48 PM
rjmay's Avatar
rjmay
Sirius
I had the same problem.
First I spent the $70 to direct connect two inputs (Sirius and Ipod) to the stock CD-cassette- AM-RM radio.
I eventually bought a scratch/dented Alpine unit from Crutchfield for $140 which had a direct input. I bought a $5 splitter cable to handle both sources. The Alpine bass, midrange and treble control made the stock speakers sound appreciately better.
I should have replaced the stock unit first.
Old Jun 21, 2007 | 08:51 PM
JJPMach1's Avatar
JJPMach1
In my truck I have it on 88.something. In my wife's ford minivan I had to put it on 107. all the other channels were fuzzy
Old Jun 21, 2007 | 08:59 PM
wiingnut's Avatar
wiingnut
Buy a PIE adapter plug into back of radio. No interference. You won't regret it. I liked my first one so much I bought one for another car. CD Quality sound
Old Jun 21, 2007 | 10:46 PM
PHWLEE's Avatar
PHWLEE
Sounds like a "sirius problem" LOL..... sorry, just couldn't resist and you have to admit it was sticking waaaay out there just asking for it.
Old Jun 21, 2007 | 10:49 PM
ford390gashog's Avatar
ford390gashog
I would go to the website www.sirus.com the direct connections are not that expensive anymore. You can also do a FM BAND search and see the best channel to use based on your zip code and FCC registered stations.
Old Jun 22, 2007 | 05:39 AM
Superdudey's Avatar
Superdudey
I lost any signal when i was in DC and wouldnt get a signal until i was 5 miles up 270. I got pissed off so i went and pulled it all out and installed a head unit with sirius built in and got everything directly connected and now i enjoy cd quality satilite radio anywhere i go Soooo sweet
Old Jun 22, 2007 | 06:32 AM
Deluxe05's Avatar
Deluxe05
I'll throw in another vote for P.I.E.'s adapter (FRD04-AUX). Install is easy...about 30 minutes. This will give you two (a left & right) input RCA jacks, and the adapter interfaces with the OEM head unit via the proprietary CAN-bus used for the rear seat entertainment option, as the head unit is also used in the Excursions.
Using an 1/8" male stereo headphone jack to RCA cable, I integrated my iPod in with the stock stereo. Having spent some time playing with it after the install, I seriously cannot tell the difference between MP3s playing from my iPod & the source CDs.
If it is any further help, I installed the adapter behind the trash hook, and ran the cable out through the hole on the trash hook. Using a 5' cable, it gives me enough extra room that I can move the iPod between the in-dash & center console cup holders, as needed.
To give you a starting place for what to look for:
http://www.logjamelectronics.com/piefrd04aux.html
Old Jun 22, 2007 | 09:15 AM
Passin Thru
HA! I LAUGHED!!!!!!!! Right..... There have to be 10,000 unemployed clowns in this country (including me)
I was a Seabee and everybody knows we build roads so all the grunts don't get their feet mudddy.
Old Jun 22, 2007 | 10:43 AM
johnnysF350's Avatar
johnnysF350
And another vote for the PIE adapter. I put one in mine and when you toggle between the FM transmitter and the PIE, the difference is night and day. Well worth the money.
