AE sensor questions
Old Jun 21, 2007 | 06:41 PM
mndiesel's Avatar
mndiesel
AE sensor questions
I have a question about the wastegate solenoid sensor. Mine read 99.11 at idle, during acceleration and WOT. I know that is not the way it is suppose to work but my question is How do I fix it? By the way my MAP sensor is bad as well.(2.3psi below BARO). Thanks Tom
Old Jun 21, 2007 | 06:44 PM
Uzumati's Avatar
Uzumati
Tom was that 2.3psi low in a stock setting or one of the tunes?
Old Jun 21, 2007 | 06:49 PM
mndiesel's Avatar
mndiesel
Alan, That was in 80 economy mode. Tom
Old Jun 21, 2007 | 07:00 PM
Uzumati's Avatar
Uzumati
Look at it in stock before you call it bad I have seen that in DP's tunes
But with the MAP reading 2.3psi low the PCM will be seeing boost lower than expected and will keep the waistgate closed longer trying to raise boost.
The 7.3L DIT Diesel Engine uses an electronically controlled wastegated GTP38 turbocharger to control the intake manifold pressure. An intake manifold pressure sensor provides readings to the PCM, the PCM compares this reading with the vehicle speed and engine load then sends a signal to the solenoid control valve. The solenoid control valve alters the pressure applied to the wastegate actuator to provide the proper position for the wastegate valve providing the proper boost pressure.
Old Jun 21, 2007 | 07:09 PM
mndiesel's Avatar
mndiesel
Alan,
You were right it went up to 14.2 in stock which is .5 low compared to Baro. Should I be taking all readings in stock or is only some of them affected. Thanks for all the help. Tom
Old Jun 21, 2007 | 07:30 PM
Uzumati's Avatar
Uzumati
Only some are effected, but is always best to go back to stock when trying to diagnose.
On the waistgate see if this will help http://www.7point3.com/AETips/Docs/Wastegate.pdf
Old Jun 23, 2007 | 12:15 AM
mndiesel's Avatar
mndiesel
Alan,
I will check the wastegate, thanks for the link. Tom
