Parts swap
Old Jun 21, 2007 | 04:32 PM
baybiker's Avatar
baybiker
Parts swap
Will the starter,alternator, injectors,o2 sensor,or anything else fitfrom a '91 302 to a "91 300
Old Jun 21, 2007 | 06:04 PM
Dean88's Avatar
Dean88
The starter and altertanter should, not sure about the others tho. Most things from a 300 will fit on a 302 including fuel pumps, Power Steering Pumps, air filters, smog pump.
Old Jun 21, 2007 | 06:14 PM
lostin90s's Avatar
lostin90s
According to parts book if both auto or manual the starter will work ,alt & o2 should work also. Some other sensors .
As for the injectors I don't know as I don't deal with 300-6 often (they don't die) . Good luck
Old Jun 21, 2007 | 09:00 PM
brown 4x4's Avatar
brown 4x4
Injectors are different. They'll physically fit but the V8's have a different flow rating. The front accessories should all work, you'll just have to switch them to the right brackets (as in power steering pumps).
