Well, It's gone.
Old Jun 20, 2007 | 10:12 PM
88 F250 DIESEL's Avatar
88 F250 DIESEL
Unhappy Well, It's gone.
Sorry [but happy] to report, the truck is gone. I traded it in. I had too, putting way too much money in it. 1 dmf in Aug '05, another in mar '07. countless trips to repair shops[ I am no mechanic]. The last straw was 2 full tanks of gas, would not run, would not let me switch tanks, had it towed to a ford dealership,Thankfully, I knew all 3 diesel techs, put on a new fuel indicator switch, wich allowed me to switch tanks. The tech told me he told service dept. to not charge me for all the time he had in it, because he could not say for sure it is fixed. I told him I was thinking about getting rid of it, he said that sounded like a good idea to him. Also told me someone had previously altered the front fuel spout & pipe. Told me probably would need that fixed before it would be exactly right. The bill was a lot less than I was quoted. After all this, I figured the best thing to do was cut my losses and get rid of it. It was running fine when I traded it in. I probably fixed everything that was wrong B4 I got rid of it. I did stay in the Ford family though, I got a 1988 f350 crew cab dually 2wd with a 460. Personally for me too expensive to have a diesel. the last year or so, spent more time working on it than driving it.
Old Jun 20, 2007 | 10:53 PM
faststang94's Avatar
faststang94
sounds like the truck is just worn out like all old cars and trucks get. well you shouldnt have much problems with the 460 its one of fords best gas engines i think. you wont get the mileage as you would a diesel, but other than that you will have plenty of power
Old Jun 21, 2007 | 12:05 AM
onereelbigfishy's Avatar
onereelbigfishy
My old man has an 89 with the 460. It'll pass everything but a gas station!
-M
Old Jun 21, 2007 | 12:38 AM
Brimmstone's Avatar
Brimmstone
Sounds like my Bronco. The 429 in it will out pull everything but my 87 diesel one ton. Of course 6 miles to a gallon suck when you are used to twelve.
Old Jun 21, 2007 | 01:00 AM
TomA92's Avatar
TomA92
I had (have) a 92 F250 4x4 with the 460 in it. I used to get 13.5 mpg on winter blend gas and 16 mpg on summer blend gas on a 200 mi trip on cruise control at 2000 rpm.
Mileage was not the problem, when the E4OD went out for the second time I could not see putting $2300 into fixing it. I bought my '86 F250 4X4 with the 6.9 for $2000. The T19 might leak a bit but it is not going to leave me stranded and cost $2300 to fix.
Anybody want a 4X4 extra cab 460 cheap?
Old Jun 21, 2007 | 08:39 AM
460429_freak's Avatar
460429_freak
if you wasn't in cal. I would want it....
yes diesels are more expensive to fix if your not able to work on them your selve
take my dads truck
87 ext cab 2wd 6.9 turbo with dne2 underdrive ... we bought it for $1000
in the 3 years we owned it I replaced...
1 raditor ($100 had it redone) $350+
1 starter ( parts truck paid $400 for it) $300
1 ip pump ( parts truck) $300-600
1 fuel pump($29)
1 air pump (parts truck) $120
1 alt (parts truck) ??
1 pollack valve (parts truck)??
all the brakes ($40-$60)
if I had a shop to do this it would have probably cost us $3000 to fix it plus the parts...
