(RSS) Reverse Sensing System
Old Jun 20, 2007 | 07:35 PM
lawlor's Avatar
lawlor
Cool (RSS) Reverse Sensing System
My RSS isn't working and I was wondering if there is a fuse for it or is it something else? Does anybody know where to get a wiring diagram?
Old Jun 21, 2007 | 08:59 AM
Bulldog_shotgun's Avatar
Bulldog_shotgun
does the (off) light stay on??
and if so can you turn it off and back on, and get the light to go out?
try backing up near a wall 4-5' and cycling the switch.
let me know what you find out.
remember the gap between the prox sensor, and the plastic housing they are in, must be free.
If it has rained recently where you are, water can cause problems also.
they also only work in when vehicle is in reverse (figured you knew that, but just to be sure)
Old Jun 21, 2007 | 09:14 AM
lawlor's Avatar
lawlor
The light does stay on once in a while. And every so often I hear a beep from it when I put it in reverse. But when I tried backing up to something it didn't work. It doesn't rain much here in SoCal so I don't think it's that. How can I check the gap between the sensor and plastic housing without taking everything apart?
Old Jun 21, 2007 | 09:51 AM
Bulldog_shotgun
sounds as if you have dirt in the gap.
pressure washer will sometimes blast them out, or air hose.
if not you will have to pull them out and wipe them off and put them back.
(there really not suited for off road use)
Old Jun 21, 2007 | 11:01 AM
F250_'s Avatar
F250_
I have the F250 fuse and wiring diagrams, but the pdf file is too large to post here in FTE. Send me an email at clevelandp@bek.com, and I'll reply with the pdf file for you.
EDIT:
Upon looking over the diagrams, the only potential reference I can find is the Parking Aid Module. might be what you need, but might not be, too. You're still welcome to the file.
Old Nov 28, 2007 | 04:54 PM
No-Tyme's Avatar
No-Tyme
Bulldog_Shotgun
Are you saying the sensors must be installed in the bumper to test? I have been working on mine and just pulled them all out and replace each one with a new sensor and they still don't work.
Buy the way I also have an 04 scab 4x4 Lariat
Old Nov 28, 2007 | 05:05 PM
VaSheriff's Avatar
VaSheriff
You can always install a ......
VR3 Roadmaster Wireless Rear View Camera System
I have one and love it! No need for the sensors then!
Old Nov 29, 2007 | 09:13 AM
Matt M, PA's Avatar
Matt M, PA
VA Sheriff....where did you mount the monitor for your b/u system?
Old Nov 29, 2007 | 09:14 PM
VaSheriff's Avatar
VaSheriff
The VR3 comes with a bracket that you bolt right onto your license plate, using the license plate bolts.
You can view the lens and bracket here....
http://www.walmart.com/catalog/product.do?product_id=4744711
Old Nov 30, 2007 | 12:36 AM
Stewart_H's Avatar
Stewart_H
http://www.walmart.com/catalog/produ...uct_id=4744711
Not the camera bro. He wants to know where you mounted the monitor.
Stewart
Old Nov 30, 2007 | 07:10 AM
VaSheriff's Avatar
VaSheriff
Stewart
It's that time of year, rushing around 24 hours a day and not paying attention to what I read.
I mounted mine at the top of the windshield right beside the rear view mirror.
I used a GPS suction mount in order to do this.
Old Nov 30, 2007 | 08:35 AM
Matt M, PA's Avatar
Matt M, PA
Thanks! Good info. I had looked at those before, and wondered how the picture quality was, etc.
I have been considering getting a new mirror with monitor biult in, etc....I'll have to check these out!
Old Nov 30, 2007 | 11:19 AM
No-Tyme's Avatar
No-Tyme
Hey! Still looking for help with the Reverse Sensor System! Any thoughts?
Old Nov 30, 2007 | 03:26 PM
kev03's Avatar
kev03
sorry! I can't help with the diagram. But I do know the wiring harness for the reversing sensors can go bad, and that you can replace the harness the sensors plug into.
Old Nov 30, 2007 | 06:28 PM
No-Tyme's Avatar
No-Tyme
Right now I am suspicious of the module because it beeps spatially and it never did that before.
