I Have A 1991 Ford Ranger 4 Cyl Duel Plug Engine.only Way I Now How To Explaine This Is. You No On Older Cars When U Go To The Store Get What U Need Come Back Out To Get In Car An Its Flooded From Gas Seeping Through Well Kinda What My Truck Is Doing I Can Start It After Its Sat For A While And Its Ok But If I Start About 15 Mins After I Turned It Off It Does This But I Can Get In An Drive It And It Comes An Goes Also Runs Like Only On 2 Cyl Please Help Me Asap
Could be a number of things, so we'll need some more clues.
Do you have a Check Engine Light (CEL) on????
If so, have you had the computer scanned for trouble codes???? If you have, post ALL the trouble codes & the order & sequence in which they were retrieved, as they can offer up good clues as to what's wrong.
Even if there is no CEL on, there could be "pending" codes stored, like mis fire, or maybe fuel pressure, or timing codes, or MAP, or MAF info , that haven't occured enough times yet, to "mature" & turn the CEL on, so we'd like to know if there are any "pending" codes in the computer.
Where are you on past & present due scheduled maitenance items????
Have you done any service or repairs just before the problem came about????
