Computer Chips & Tuners
Which chip for a PSD
Old Jul 21, 2001 | 01:12 AM
jkiser96's Avatar
jkiser96
I have a 96 F-350 PSD with 137,000 miles & I want to get a little more out of it. I am running 4" lift & 36" x 14.5 Mickey Thompsons,it still will get up & run but I just want a little more.Any suggestions are greatly appreciated.
Old Jul 21, 2001 | 07:33 PM
D's Avatar
D
The most we can add to your truck is 50 hp and 100 ft/lb torque. To add more would require a larger exhaust system, a larger downpipe, and a pyrometer. Check at the online store here. Your code will be on the ecu. Your ecu is under the hood where the fender liner meets the firewall on the passenger side. You will need a small mirror and a light to see the code. It is on the side of the wiring harness facing the fender. Call fo assistance, we can talk you through finding your code.
1-877-399-6417
Thanks
Danny
2001 Cobra-Lazer Red
3:73 gears
Steeda Tri-Ax Short Shifter
DiabloSport Chipped
Old Jul 22, 2001 | 08:18 PM
jkiser96's Avatar
jkiser96
Thanks for the info I will call this week.
Old Jul 23, 2001 | 10:12 PM
D's Avatar
D
