Gear wont shift!!!!!!!
Old Jun 20, 2007 | 06:35 PM
86I6WontStart's Avatar
86I6WontStart
Hey guys , heres my question, it just started this afternoon.
I have now a 79 f-150 I-6 god truck, but at the light I took off first, then 2nd, then 3rd but I wanted to downshift back to 2nd I coulnt, went back to third.
I got home got underneath, i didnt see anything abnormal, so i went around the corner, first ok, 2nd ok, 3rd ok, 4th ok. came to stop sign first ok, 2nd ok, 3rd made a small grinding noise and a clunk, then 4th ok.
Again stop sign first ok, 2nd ok, 3rd ok, need to turn wanted to downshift to 2nd but I coulnt, so i tried go tofirst no problem, then2nd ok, 3rd ok and I got home
tranny is the one that comes with 3 small feet if you know what i mean??
Please any advise will help.
Thanks
Old Jun 20, 2007 | 07:35 PM
Jermafenser's Avatar
Jermafenser
No, I don't know what you mean regarding the transmission.
It's either:
New Process 435 or Borg-Warner T-18. That's a toploader transmission, 4-speed, very long shifter. Or it has the Clark 4-speed overdrive transmission with the shorter shifter that's closer to the bench seat.
Old Jun 20, 2007 | 08:41 PM
Mrcorey5's Avatar
Mrcorey5
I am puzzled also,please elaborate.
Old Jun 20, 2007 | 08:57 PM
86I6WontStart
Ok heres again: Truck has manual transmission, i cant go to 2nd gear .
but thats not all the time.
Sometimes it will go if i shift it nice and slow.
now i shift first then third because 2nd its hard to do it.
Thanks
Old Jun 21, 2007 | 07:19 PM
86I6WontStart
the truck has a
Clark 4speed o/d, short shifter close to the bench.
Old Jun 21, 2007 | 07:22 PM
73f350sc's Avatar
73f350sc
Sounds as if you just need a rebuild on the tranny...but...go under it and make sure that all of the linkages are connected and in good working order as well.
-Chris
Old Jun 21, 2007 | 09:43 PM
Jermafenser
It's been said (no personal experience...) that the Clark OD unit does not like being abused. It's a light duty transmission, that's for sure. Assuming you were always easy on it, it may be the synchronizations may be worn out from wear and tear.
To check for this, pull the top cover and look at its internals. The brass synchronizations should have sharp edges on the teeth. If they're worn off, then you have found the problem you're experiencing. The other thing is, from what I read, the gears between 1 and 2 is a WIDE jump, so that is already troublesome if you're not keen on it.
Old Jun 23, 2007 | 07:31 AM
86I6WontStart
Ok guys i'll go check , i'll keep you post it. Thanks for the advise.
Be right back.
