OIL Temperature Probe??
Old Jun 20, 2007 | 05:57 PM
USMC Diesel's Avatar
USMC Diesel
Question OIL Temperature Probe??
I’m installing an oil temperature gage on my 06 PSD.
Where is the best place to put the probe?
I was thinking the line going to the oil cooler, but I also heard the oil filter cap.
What do you all think?
Old Jun 20, 2007 | 06:17 PM
duffman77's Avatar
duffman77
The ECM already monitors oil temp. You dont need to add anymore sensors if you used a Quadzilla Commander which monitors a bunch of features as well.
http://www.quadzillapower.com/products/commander.html
Old Jun 20, 2007 | 06:44 PM
southbound35west's Avatar
southbound35west
i put my oil psi sensor unit on top of my aluminum oil cap which was tapped for this purpose, if i put in an oil temp gauge i will put a tee fitting on top of my oil cap and get temp from one side and psi from the other side......check my gallery for pics of this...
Old Jun 25, 2007 | 11:48 AM
USMC Diesel
Is there a plug on the side of the block where I can put the Oil Temp Probe?
Old Jun 25, 2007 | 01:09 PM
Lonewolftx's Avatar
Lonewolftx
Thumbs up
No there isn't. Some drill the pan and install there. and . . .
BTW, THANK YOU for your service to our country and too all of us!
Old Jun 25, 2007 | 01:16 PM
USMC Diesel
Thanks Lone Wolf.
I'm looking at the 6.o Bible and I see there is an Oil temp probe already installed.
I'm going to look at the oil assembly at lunch and see what I can do there.
I also noticed that there is an Oil pressure test port I may remove the test port and put the probe there, what do you all think?
Old Jun 25, 2007 | 01:25 PM
Lonewolftx's Avatar
Lonewolftx
Wink
Hope it works out. Let us know here as well. Good luck w/ it.
Old Jun 25, 2007 | 01:49 PM
USMC Diesel
I looked at it and unless I want to drill and tap the oil filter housing the best way I think is to buy a billet oil filter cap drill and tap that.
