automatic transmission question
Old Jun 20, 2007 | 07:50 AM
saddler53's Avatar
saddler53
I have 2001 V10,the truck felt like it was cuting out as I climb a hill,had it scaned nothing found.I was coming home yerterday when it started cuting out again I cut the overdrive off, it stoped the problem,so before i go to the trans shop.I though I check here to see if anybody has had this problem.
Old Jun 20, 2007 | 09:47 AM
BBrown's Avatar
BBrown
Might be a dirty fuel filter, I'd change it before trying other more expensive solutions. Just my 2 cents worth. Good Luck !
Old Jun 20, 2007 | 01:57 PM
Monsta's Avatar
Monsta
Sit. Stay.
How fast were you going up the hill?
What was your RPM?
When you turned off OD did it drop to 3rd?
How many miles are on your truck?
Personally, I suspect you have a bad Coil on Plug.
Old Jun 20, 2007 | 04:05 PM
jackrista's Avatar
jackrista
could have a bad boot on one of you coils.
Old Jun 20, 2007 | 09:09 PM
jspringator's Avatar
jspringator
I don't think I would go to a transmission shop first.
