351w timing
Old Jun 20, 2007 | 07:45 AM
Offroader6's Avatar
Offroader6
351w timing
I've got a truck that I bought with a mysterious 351w which was dropped in it. I ran the numbers off the block and it's out of a 1972 Gran Tarino. I know the guy put flat-top pistons in there, but that's all I know. I have installed holley throttle-body injection and am to the point where I need to check the timing.
My problem is that the guy did a serpentine conversion and I can't see or get to any sort of marks on the balancer. The engine runs decent, but has a hickup under load about 2400 rpm. How should I go about setting the timing?? What degrees should it theoretically be set at? I know you're not 'supposed' to go by ear or feel, but I think that's my only option. It's got a vacuum advance distributor and I'm running a MSD 6AL Offroad ignition.
Thanks in advance for any help!
Old Jun 20, 2007 | 11:23 AM
ken75ranger's Avatar
ken75ranger
I have the same problem with my setup. I made a mark for TDC I can see and time it with and adjustable timing light. The 5.0 motor I'm running now likes 10 degrees but I've seen 6-14 work.
Old Jun 20, 2007 | 12:28 PM
Conanski's Avatar
Conanski
If the balancer is corroded you may need to hit it with a steel brush to clean it up and then highlight the timing marks with chalk or some such. But then, if the timing pointer is in the wrong place it may all be for not. You can verify by bringing the #1 cyl up to TDC, the balancer marks should then be under the timing pointer, if not, move the pointer.
Your stumble under load may not be timing related however, could simply be arcing between plug wires or some metal part. Be sure to keep wires seperated where they follow sequentially in the firing order, so cylinders 7&8 on the car/5.0 truck order, and 5&6 on the HO/351 order.
Old Jun 20, 2007 | 04:40 PM
Offroader6's Avatar
Offroader6
Thanks for the tips! Part of it is getting the holley fuel injection dialed in, but it's odd how the engine chugs under load. Similar to if you were just letting on and off the throttle every second
