Locking Hubs
Old Jun 19, 2007 | 09:36 PM
THE KING's Avatar
THE KING
Locking Hubs
I thought i would try here saying the Big Bronco thread seams dead tonight and i need some help fast! I have a 95 bronco with lockouts. I did a front brake job on it and the hubs will not seal. I have all the allens screwed in tight and i can wobble the hubs around. Im also getting grease out of them and i dont want to run the bearings dry. I also stripped out the heads on some of them for a last attempt to get them tight. Any answers to what i should do before i let a mechanic do it? I have most the tools and know how to do it myself. PLEASE HELP!
Old Jun 19, 2007 | 09:53 PM
75F350's Avatar
75F350
I seem to recall an o-ring seal that had to be in there to keep the good stuff in, and the bad stuff out.
Old Jun 20, 2007 | 06:06 AM
79superduty's Avatar
79superduty
if you have all the parts in correct and the big snap ring in and its still leaking a little silicone around the hub might help. if it still continues to leak an aftermarket hub is well worth the money..
