Header Help
Old Jun 19, 2007 | 06:38 PM
classic4x4's Avatar
classic4x4
Exclamation Header Help
I have a '77 F150 Custom that has a 360 from a '75 Ford, that's what I believe it to be. I would like to get a set of headers for the truck, and I'm wondering whether or not I should order for the truck year, or the motor year and CID, or if it doesn't matter.
I'm not sure if the motor is out of a 2wd or a 4x4, becasue I noticed that part of the driver side engine mount was torched out to make room for the stock exhaust manifold. I don't want to order a set of headers and find out that they don't fit.
Thanks for your help guys.
Old Jun 24, 2007 | 05:32 AM
bryonwleeper22's Avatar
bryonwleeper22
Throw down some VIN numbers and find out what it came with. I cant help but there are a few guys on here who have mad skills decoding. Maybe it had a I-6 in it before? IDK just a thought. I would personally go with the year of the motor and weatrher or not its a 2x or 4x. Im pretty sure the main difference is the frame right? The older Fords with the divorced x-fer case had a narrower frame? Or im just making that ish up? If not someone will correct me
Old Jun 24, 2007 | 01:12 PM
classic4x4's Avatar
classic4x4
The truck had a 400 in it before, I already ran the VIN.
Old Jun 24, 2007 | 11:55 PM
bryonwleeper22
Then cant you just order it for your year of truck and just order it for the 390? I know the 351-400 biz and 360-390 is the same sort of deal right. Maybe if you can get it for the 390 so there is no problems but check with the oter 360-390 guys. If there is no option to order it for the 360/year of PU. I think a few came with a 390 but like I said im not positive.
This is what I found in a quick search:
http://www.stans-headers.com/ford_headers.htm
<TABLE cellSpacing=0 cellPadding=2 width=540 border=1><TBODY><TR class=n2r bgColor=#caddcc><TD align=middle width="15%">PART#</TD><TD align=middle width="8%">YEAR</TD><TD align=middle width="43%">APPLICATION</TD><TD align=middle width="14%">ENGINE</TD><TD align=middle width="10%">CODES</TD><TD align=middle width="10%">PRICE</TD></TR><TR class=n2 bgColor=#f3f3f3><TD align=left width="15%"> 222Y</TD><TD align=middle width="8%">65-76</TD><TD align=left width="43%">Pickups (2WD)</TD><TD align=left width="14%">352-390</TD><TD align=middle width="10%">1,4,9</TD><TD align=right width="10%">401.50 </TD></TR><TR class=n2 bgColor=#ecebd0><TD align=left width="15%"> 222Y-14</TD><TD align=middle width="8%">65-76</TD><TD align=left width="43%">Pickups (2WD)</TD><TD align=left width="14%">352-390</TD><TD align=middle width="10%">1,4,9</TD><TD align=right width="10%">467.50 </TD></TR><TR class=n2 bgColor=#f3f3f3><TD align=left width="15%"> 244Y</TD><TD align=middle width="8%">65-76</TD><TD align=left width="43%">Pickups (4WD)</TD><TD align=left width="14%">352-390</TD><TD align=middle width="10%">1,4,9</TD><TD align=right width="10%">412.50 </TD></TR><TR class=n2 bgColor=#ecebd0><TD align=left width="15%"> 244Y-14</TD><TD align=middle width="8%">65-76</TD><TD align=left width="43%">Pickups (4WD)</TD><TD align=left width="14%">352-390</TD><TD align=middle width="10%">1,4,9</TD><TD align=right width="10%">489.50 </TD></TR><TR class=n2 bgColor=#f3f3f3><TD align=left width="15%"> 244Y-Low</TD><TD align=middle width="8%">75-76</TD><TD align=left width="43%">Pickups (4WD) F250</TD><TD align=left width="14%">390</TD><TD align=middle width="10%">1,4,9,10</TD><TD align=right width="10%">412.50 </TD></TR></TBODY></TABLE>
Hope this helps out, Just have to compare the frame differences I guess
Old Jun 25, 2007 | 04:40 AM
bryonwleeper22
This guy is near me or at least on Portland's CL give him a call they look perfect and I have a set on my 400.
http://portland.craigslist.org/clc/pts/358510941.html
