Sponsored by: Real Truck
Castle Nuts Wont Work
Old Jun 19, 2007 | 06:01 PM
Rackpatrol's Avatar
Rackpatrol
I changed all of my tie rods this weekend . and when I went to torque them down to 67 ft. lbs. as per specifications. I found out that the castle nuts went on to far for the cotter keys to even touch the nut let alone go inside the slots. It is like the studs were to long. So when I compared old ones with the new ones they were almost a 1/2" longer. this was on the outter ( both left and right ) tie rod ends. of my ( 2000 EX 4x4 7.3 ). Oriley's said they were the right parts. every thing else looked good and fit good except for the castle nuts. SO NOW WHAT DO I DO.
Old Jun 19, 2007 | 06:04 PM
mongo75's Avatar
mongo75
Stack washers under the castle nut.
Old Jun 19, 2007 | 06:18 PM
Rackpatrol's Avatar
Rackpatrol
I WOULD BUT i FEEL MTHAT THE FRICTION CAUSED BY TORQUEING WOULD BE LOST AND MIGHT WORK LOOSE.
THANKS
Old Jun 19, 2007 | 06:20 PM
rbaker6336's Avatar
rbaker6336
what you need is grade 8 washers
Old Jun 19, 2007 | 07:04 PM
rbaker6336's Avatar
rbaker6336
your problem is why I never buy off breed suspension or brake parts
Old Jun 19, 2007 | 09:30 PM
Rackpatrol's Avatar
Rackpatrol
I have always had good luck with MOOG
Old Jun 19, 2007 | 10:38 PM
KrenzyRyan's Avatar
KrenzyRyan
I have the same problem after installing my DR crossover steering - some of the castle nuts that were supplied were too short to reach the cotter pins...
Old Jun 20, 2007 | 12:05 AM
mongo75's Avatar
mongo75
I know using extra washers is not the best if you CAN get longer castlated nuts, but once you get the cotter key in place, nothings going anywhere. I have to do this on helicopter flight controls sometimes, and it's accepted practice.
Old Jun 20, 2007 | 05:06 PM
Rackpatrol's Avatar
Rackpatrol
I have seen a metal cap that fits over a nut and it has points on it that would extend the castle nut so that the key would fit through it. One came with the tie rod that fastens to the pitman arm ( left inner tie rod I think ) But I dont know what the fancy cap is called.
Old Jun 20, 2007 | 06:56 PM
Ed in Maine's Avatar
Ed in Maine
Noticed the same thing on my left inner tie rod end, and it is a moog. Was not as long as yours, but it could use a washer or two.
zxwut?
34
Sep 23, 2024 10:08 PM
Pridnjoy
Nov 29, 2015 11:39 PM
johnson.jeff.a
Nov 13, 2015 10:57 AM
bryanmartin
Jul 27, 2015 07:06 PM
AIbandit
Mar 3, 2013 09:57 PM
