tire size??????
Old Jun 19, 2007 | 05:51 AM
f-14fixer's Avatar
f-14fixer
tire size??????
I am thinking about putting a 3" body lift on my 04 f-150. Does anyone know what the largest size tire I can go with without cutting anything?
Old Jun 19, 2007 | 11:12 PM
adbarron's Avatar
adbarron
You could comfortably put up to a 35 inch tire. It really would depend on the wheel back spacing you have. I would suggest a leveling kit or a suspension lift kit instead of a body lift. There are a tremendous amount of posts on leveling kits and lift kits on here. Do your home work before your use a body lift.
Old Jun 19, 2007 | 11:52 PM
mattd17's Avatar
mattd17
i agree... i would go with a leveling kit and then run up to 35's..... personally i just dont like the body lifts. but it is totally up to you. a body lift is a fast way to get a couple cheap inches of clearance, but they dont look as clean as a susp lift. there are tons of people here with every combination of lift/tires, etc to help you in your decision.
