1978 - 1996 Big Bronco
lift ??
Old Jun 19, 2007 | 01:33 AM
bassproguy07's Avatar
bassproguy07
lift ??
why is my buddys 96 bronco with a 6 inch lift the same height as my other friends blazer with a 4 inch lift? we have receipts from 4wheel parts that say its a 6 inch pro comp lift but it sits the same height as our buddys 89 blazer with 4 inches....is this because blazers are bigger stock than broncos or what?
Old Jun 19, 2007 | 08:54 AM
Kemicalburns's Avatar
Kemicalburns
well buying anything from 4wheelparts was the first mistake. those guys are idiots and most arent even ase certified to even work on vehicles. I would take all the parts numbers you can and reference them.
what year blazer? leaf springs or IFS type? what size tires.
Old Jun 19, 2007 | 10:32 AM
MBBFord's Avatar
MBBFord
If the tire sizes are the same, then it sounds right to me.
The 92-96(I think) broncos need a 6" lift to clear 35s, but some of the older ones can clear 35s w/ a 4".
My 79 has a 6" and 36s, but I could easily clear 38s.
Old Jun 19, 2007 | 11:48 AM
bassproguy07
89 blazer solid axle front end......checked the receipts and its not from four wheel that was the tires, its from a off road shop in san antonio, it has 35's on it
Old Jun 19, 2007 | 12:17 PM
Kemicalburns
the wheel wells on the chevys make it hard to run large tires without more lift then what most rigs would need.
