Cold running hickups
Old Jun 18, 2007 | 11:22 PM
all4ford's Avatar
all4ford
I just bought a 94' F150 with a 5.8L and it has a huge miss when just started. It almost seems like it is flooding. Once it runs about a minute it runs great. It doesn't seem to make a differance if it is cold or warm. I replaced the plugs, wires, rotor, cap. This is driving me crazy. I scanned for codes and it came up with code 31. Something about the EGR voltage. I unplugged the EGR and no differance. I disconected the battery and it cleared the code and nothing else came up after a drive. Just started it again after cooling for 1/2 hour. It has a miss again. Then went away. When it stops missing the idle goes up a little.
Any help would be great.
Thanks
Old Jun 18, 2007 | 11:33 PM
all4ford's Avatar
all4ford
Another thing I forgot to add was the fuel pressure regulator ticks when you shut the engine off.
Old Jun 18, 2007 | 11:45 PM
NeXtras's Avatar
NeXtras
sure it wasnt a code 32 (im assuming air bag light) if its that its clock spring which shouldnt effect how it starts..
and a lot of things tick when you shut a car/truck off cause its cooling down and metal is retracting... sire its that regulator?
mayb a bad fuel filter?... not too sure
Old Jun 19, 2007 | 12:00 AM
all4ford's Avatar
all4ford
It may be 32 because the airbag light flashes and the horn doesn't work. I bought a fuel filter too but haven't installed it yet. I'm not 100% it is the FPR but the ticking is in that area. It isn't a cooling tick, it is loud and only does it about 10 seconds. I will check fuel pressure too. just to make sure.
I have owned many ford trucks and this is the first time I've had this happen. Could an ignition module do this?
Old Jun 19, 2007 | 12:07 AM
NeXtras's Avatar
NeXtras
That code is definetly clock spring, which is a very common problem for this generation of the F-Series. other than that i dont know what to tell you.... mayb fuel injectors?? try puttin that injector cleaer additive in your tank when you fill up. If that doesnt work replace all 8 of em
Old Jun 19, 2007 | 01:10 AM
all4ford's Avatar
all4ford
I put fuel injector cleaner in one of the tanks a week or so ago. It is weird because it ran great for a few days then went to **** when I first started it. I do need to replace the fuel filter though. It looks to be original.
Old Jun 19, 2007 | 07:57 AM
NeXtras's Avatar
NeXtras
What about fuel injectors? you may want to replace those
Old Jun 19, 2007 | 09:45 AM
Bruce R Leech's Avatar
Bruce R Leech
it sounds like fuel injectors or at least one is sticking open and bleeding fuel in to the manifold after shut down. check them with a gage first to see if that is it.
Old Jun 19, 2007 | 08:29 PM
all4ford's Avatar
all4ford
I have fuel pressure in the fuel rail so I doubt it is a injector. It would leak down the pressure wouldn't it? It seems to be running decent today. I removed the ignition module from the heat sink and cleaned it up and put dielectric grease on it. That made it run good. Then I changed the fuel filter just in case. I will have to drive a bit to see if it went away.
Thanks guys
Old Jun 20, 2007 | 03:28 AM
dieselburner6.0's Avatar
dieselburner6.0
i have a 95 F-150 and same problem got my injectors cleaned and seamed to help but not perfect i was told there is one more thing that can be replaced. It’s a sensor that acts like a choke. my truck right know seems to be flooding when you start it rough starting and idles bad at first once i get some more cash its going back in to get that sensor or what ever it is looked at sorry for not knowing the right Terminology
Old Jun 20, 2007 | 11:32 PM
all4ford's Avatar
all4ford
Is it called the fast idle solenoid or motor or something like that? I think I know what your talking about. It is running good now but it is warm out. I'll have to see when it gets colder.
Thank you for great info.
