Lost Need Serious Help
Old Jun 18, 2007 | 04:47 PM
FIREFIGHTERHFD61's Avatar
FIREFIGHTERHFD61
Question Lost Need Serious Help
Ok In March I Bought A 2004 F-350 Srwcrew Cab 4x4 Lwb Truck With 4.10 Gears It Ran Great I Have A Couple Problems Now Though 1.] If I Kick It Down Coming Up A Steep Grade With Or Without A Load It Will Over Heat Spewing Water From The Driver Side Temp Guage Goes Up And Check Gage Lite Comes On 2.] I Was Driving Yesterday And The Out Put Hose From The Turbo To The Intercooler Blew Off I Put It Back On Checked The Clamps And Blew It Off Again Within 100 Yds Clamp Appears To Be Good No Cracks Or Etc Any Help Would Be Greatly Appreciated 139,000 miles
Old Jun 18, 2007 | 04:53 PM
barnbridge's Avatar
barnbridge
If you have less than 100,000 miles the engine is still under warranty, let the dealer take a look. My guess is your turbo is overboosting causing excessive cylinder pressure which stretches the headbolts and releases hot exhaust gas into the cooling system which overheats the engine.
Old Jun 18, 2007 | 05:44 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Is the truck stock?
I would agree with either head bolts, head gasket problem.
Also check TSB 06-3-8 as this sounds like your water problem. Go to top of this screen and go to full text TSB.
Also check TSB 05-13-5 for the hose problem
Old Jun 19, 2007 | 11:18 AM
FIREFIGHTERHFD61
The Truck Has 139000 Miles And Is All Stock Except For A Predator Programmer Which Has Only Been Set On 65 Horsepower Mode
Would Stretched Head Bolts Or A Bad Head Gasket Cause The Turbo Hose To Blow Off
Also The Truck Gets Horrible Fuel Milage 10.5 Without The Programmer 12.5 Mpg With The Programmer I Know The Gear Makes Up For Some Of This But Is This Normal
Old Jun 19, 2007 | 12:15 PM
tttario's Avatar
tttario
What does your boost gauge read after you put the throttle to the floor, before you had the issue. If you are over 30, you have probally been stretching your head bolts for a while now.
Turbo hose blowing of is a TSB as bigredtruckmi indicated. But if you are overboosting the intake, this will happen premature.
Running a 10000# truck with 4.10 gears will never get you good Fuel Economy. 10.5-11 would sound right to me. You are getting the other 2 mpg from the increased horsepower the tuner is supplying.
Old Jun 19, 2007 | 12:18 PM
FIREFIGHTERHFD61
No Boost Gage Yet So I Dont Know The Pressures
Old Jun 19, 2007 | 12:21 PM
tttario's Avatar
tttario
Also, if you are replacing your head studs, you should go with ARP Head Studs. Especially if your decide to keep the predator.
I would highly recommend talking to Matt at LIPD. 1-888-229-0502. He can supply you with the head studs and a real SCT XCal2 tuner that won't give you issues like this.
Old Jun 19, 2007 | 03:50 PM
bigredtruckmi
Veteran: Navy
The 4:10 gears will hurt the mileage. My 04 with 3:55 gets around 18 if I keep my foot out of it and run under 70.
Old Jun 19, 2007 | 04:20 PM
blackhat620's Avatar
blackhat620
"Predator" "chips/inline modules" are death to the 6.0 & Torqueshift (Predator is one of the ones at the top of the do Not use list). Couple this with no gauges and you are towing, this is a recipe for disaster. More than likely blown head gaskets or EGR cooler or both. Also could have turbo problems on top of all this.
FYI if they have to do head gaskets, pray that there are no star burst patterns on the pistons, cause if there are then you will not be covered by warranty as this is one of the signs of using a "chip/inlilne module"
Good luck
