Oil Change - OOPS!
Old Jun 18, 2007 | 08:55 AM
Diesel Man's Avatar
Diesel Man
Oil Change - OOPS!
I changed oil yesterday and all went well until I realized I had droped that little copper washer and put the drain plug back in without it.
Question, has anyone else done this and did it cause it to leak? Or can I just wait until next oil change and put it back then?
I hate to dump all that new oil if I don't need to.
Thanks for any advice.
Old Jun 18, 2007 | 09:03 AM
satcom40's Avatar
satcom40
Well you did it yesterday do you see any oil under the truck today. If yes you may want to install the copper gasket. If No then wait till it leak or next oil change.
my 2 cents. John
Old Jun 18, 2007 | 09:04 AM
69cj's Avatar
69cj
If it doesn't leak you are O K. Sort of a case by case thing
npccpartsman's Avatar
npccpartsman
Ouch--yes it will leak. I'd be surprised if you weren't leaking now. Do yourself a favor and order a fumoto valve from www.fumotovalve.com. Makes oil changes infinitely easier and you don't have to worry about losing or replacing that little copper washer again. FWIW--you can always catch the oil in a clean container and put it back in your engine, but definitely check it. An oil change ain't worth losing a motor over for sure!
Old Jun 18, 2007 | 10:30 AM
hott-rodd's Avatar
hott-rodd
I agree with the clean container and reuse if it's leaking.
You can probably get the washer on before all the oil runs out.
Old Jun 18, 2007 | 12:13 PM
F250tuff's Avatar
F250tuff
Let the engine cool. Loosen the plug. As it is comes out of the oil pan, plug the hole with one of your fingers. Use the other hand to wipe down the plug and put the copper washer back on it. Remove your finger from the hole and quickly put the plug back. You should be able to do this without losing more than 1/4 to 1/2 quart of oil.
Old Jun 18, 2007 | 12:29 PM
Diesel Man's Avatar
Diesel Man
Thanks guys.
It's not leaking now but I haven't run it yet.
Yes, I was thinking the same thing F250tuff said.
Even if it's not leaking, I'll keep worrying about it. Might as well bite the bullet, take my oil bath and get-r-done.
Old Jun 18, 2007 | 12:40 PM
20046.0PSDX's Avatar
20046.0PSDX
I second NCP's suggestion that you get yourself a Fumoto-valve as it will make future oil changes a snap and eliminate that pesky little washer if nothing else.
Old Jun 18, 2007 | 01:24 PM
X-Hibition's Avatar
X-Hibition
Here is a trick my little brother taught me, and I didn't believe it until I tried it. I have done this successfully three times (don't ask).
Take your shop vac, put a shop towel over the end of the hose, push it down against the oil fill tube, and turn on the shop vac. You have now created negative pressure (suction) in the engine and can now remove the drain plug and re-install your copper washer.
I haven't done this on a fifteen quart system, but the physics are there. I have used it successfully on a 5 quart and 7 quart system. You will be able to hear the gurgling and watch the oil move around with the drain plug off, but no loss of oil.
Try it, have fun. It does work.
Old Jun 18, 2007 | 01:37 PM
OZX1's Avatar
OZX1
Most of which will run down your arm into your pit
But really... if you get prepared upfront, F250tuff's method will get the job done.
Old Jun 18, 2007 | 01:52 PM
msgtg's Avatar
msgtg
There's a copper washer on the plug?
Now I'm worried! I've done two oil changes and didn't know this. My last change was 2 weeks ago! I always wipe the plug off before the reinstall so I know I would have seen one if it was there!
It's not leaked a bit...and as I said, I've just done the second oil change.
Old Jun 18, 2007 | 04:56 PM
WishIhada7.3's Avatar
WishIhada7.3
it's on there im sure...most of the time they are plastered to the drain plug and painted black because the oil pans are painted with plug installed from the factory...
Old Jun 18, 2007 | 05:01 PM
racecort_91's Avatar
racecort_91
the shopvac trick works verry well i have done this. i worked at a oil change place for 2 years. you should see a costmers face when you bring out the vac.
Old Jun 18, 2007 | 08:12 PM
msgtg's Avatar
msgtg
Thanks wishi! I was a little worried there for a minute...but it hasn't leaked in the 11K miles I've put on it.
I'll just have to pay attention and look for it next time.
Thanks Pal!
Old Jun 18, 2007 | 08:17 PM
WishIhada7.3
Thanks Pal!
your welcome and actually you should be able to see it looking at the drain plug...if the plug is flat on the pan like there is nothing between that and the pan then its missing.
