Sponsored by: Real Truck
should I change tires
Old Jun 17, 2007 | 09:48 PM
country2's Avatar
country2
I bought a set of BFG 295/75/16s for a 99.5 F-350. I bought the truck to pull my 10K fithwheel. I towed it this weekend and thought it would do better than it did. It just seemed like it was stuggleing. the truck is stock. I am fairly light footed but when I would put my foot in it the EGTs were ip around 1000. It does a little better with over drive off but I would have though the truck would have towed in OD. Also it has the 3:73 rear end. Should I have gone with the stock 265s for towing? Is that making that big of a differance.
Thanks
Paul
Old Jun 17, 2007 | 09:53 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, your larger tires are throwing off your overall gear ratio. If you want your performance back, you're going to have to either go back to stock tires, or re-gear your front and rear differentials to a lower ratio (4.30 to 4.56 should be great).
Old Jun 18, 2007 | 10:51 AM
country2's Avatar
country2
I looked on BFG web site before I bought the tires and there is only about 1.5" diference in the 265 and the 295. At the time I did not think that would make a big difference. I wanted white letters so I went with them I liked the looks, but I guess I am going to have to go with different tires.
Anyone have suggestions on goo towing tires that are 265/75/16 and look good.
