Wanting Dics brakes?
http://www.blackbirdscustomtrucks.com/index1.html
an other option you can go, is swapping out the front axle form a new truck. I have a 72 f-250 4x4 that I plan on changing over to disc brakes. I'm going to get the front axle from a 77-79 f-250 4x4. I think this is the less complicated option.
Hope this helps...Russ
P.S. when changing over to disc brakes you also need to get to get a different power brake booster, master cylinder & and proportioning valve
