Possessed door locks!!
Old Jun 17, 2007 | 06:03 AM
insuragator's Avatar
insuragator
My wifes 99 Exp electric door locks have started just going off repeatedly. They will try to lock/unlock over and over again 15-20 times without us touching them. Has anyone had this problem?
Old Jun 17, 2007 | 09:11 PM
insuragator
Any Help?????
Old Jun 17, 2007 | 09:22 PM
dcsmith's Avatar
dcsmith
For what it's worth
I just learned the other day from this FTE web site that if you leave your key in the ignition it will automatically unlock the drivers side. It probably has nothing to do with your issue. People had written about disconnecting a wire at the ignition switch in order to make the door chime not actuate when the door is open. When the wire is disconnected the "security feature" thinks the key is in thus unlocking the door. I'm only saying maybe your wire is disconnected or has a loose connection. I doubt it is related. Just something to think about.
Old Jan 2, 2008 | 08:10 PM
3BBB's Avatar
3BBB
did you ever get your problem resolved? My wife's Expi is doing the samething and it's driving me crazy!
Old Jan 2, 2008 | 08:42 PM
insuragator
We finally took it to the shop. They installed a new actuator and the locks worked great after that. Good luck!
Old Jan 2, 2008 | 09:02 PM
3BBB's Avatar
3BBB
Thanks for the response. Do you know which actuator they replaced?
Old Jan 4, 2008 | 07:10 PM
insuragator
Not quite sure. I do know that it was about $475 for the parts & Labor.
