Doctor needed!
Old Jun 17, 2007 | 01:10 AM
weberr7's Avatar
weberr7
Doctor needed!
I made my first road trip pulling the 25' 7100lb trailer with the family to Yellowstone</ST1lace from southern CA. My excursion developed a cough when pulling up hills. I initially thought it was what I have read the infamous "turbo fart", but it really hindered my towing performance so I am thinking it is more than just the fart.
When pulling a grade 5-12%, 50-65mph, rpm 2000-3000, Pyro 8000-1200, tranny 150-190, the turbo coughs. I get clouds of black smoke during each cough and the turbo gauge accurately reads what is going on. I tried giving it some pedal and it pins the gauge at 30 and I let off the pedal and it still coughs between 10-30 on the turbo gauge. During every cough, the turbo boost gauge jumped around up and down.
The service engine light came on and off 3 times over the 8 days on its own. I pulled the codes and it read the P132B code. I called the dealer and the tech said it was low or high turbo pressure alert. He said it could be from a slight leak. Please let me know if you have seen this before and what I can expect from the dealer. Thank you!<O</O
Old Jun 17, 2007 | 10:52 AM
weberr7's Avatar
weberr7
I forgot to mention that the excursion is stock. This also happened on a trip to Arizona a few weeks back without the trailer. Thanks guys.
Old Jun 17, 2007 | 11:08 AM
fatheadon1's Avatar
fatheadon1
it sound like i had the same thing with my 05 mine went back to the dealer and got a egr and reflash and has been good for the last15k
Old Jun 17, 2007 | 11:50 AM
barnbridge's Avatar
barnbridge
Do you have less than 100,000 miles? If so the engine, including the EGR and turbo are still covered under the $100 deductible warranty. My guess dirty EGR. You could pull it out and clean if necessary. I think there are directions in tht tech folder.
Old Jun 18, 2007 | 06:04 PM
weberr7's Avatar
weberr7
Update...The dealer called and they are replacing the turbo. The service advisor said that normally they just clean it up but there was a lot of rust in it. My first question is, am I going to lose my whisle? He said it will be ready tomorrow. Thanks for your feedback on this topic.
Old Jun 18, 2007 | 08:08 PM
msgtg's Avatar
msgtg
Nope, you should still get the turbo whine.
Good Luck!
