I have a 1991 F150, and I have replaced the timing gears and chain, how do I find what torque specs I need on the bolts when I put it all back together?
Also, when I checked the front differential lubricant it seemed much lighter (weight wise) than the rear differential. Is this OK? It was pretty clean but I was not sure if there was a reason for the difference. Can I find that in the Haynes manual as well?
