fuel problem?
Old Jun 16, 2007 | 10:35 PM
wentworth's Avatar
wentworth
fuel problem?
I was wondering the trouble spots for losing pressure in fuel line when turned off. Any help would be appreciated.
94 250 7.3 idi
Old Jun 17, 2007 | 12:02 AM
PLC7.3's Avatar
PLC7.3
What is your problem......
Our diesel fuel system does not retain fuel pressure......it is an open circuit back to the tank(s) It is a closed loop as far as any air intrusion.....there should be no air holes/leaks or fuel drain off will occur. There would be hard starts or starts with stalling and major cranking required to re prime the IP if there is drain off.
Old Jun 17, 2007 | 12:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
wentworth,
Welcome to FTE and the IDI diesel forum.
As PLC7.3 stated, the return lines do not let any pressure remain in the fuel lines when the engine is not running.
Old Jun 17, 2007 | 06:24 PM
wentworth's Avatar
wentworth
new to idi
Since I'm new to idi, and not a mechanic by any means, I'll just tell ya'll my problem.
When I start the truck after it's been sitting for several hours, it takes 15-20 secs. to fire up. If it's only been an hour or so it starts perfectly.
So, if there are any opinions I'd take 'em.
94 250 7.3 idi stock
Old Jun 17, 2007 | 06:51 PM
Dave Sponaugle
You have air intrusion.
Replace the return lines and the O rings under the return line tees.
