6 Disk Mp 3
Old Jun 15, 2007 | 10:41 PM
HEARTBEATTHIS's Avatar
HEARTBEATTHIS
6 Disk Mp 3
06 F150 what is bit rate on factory disk player. want to make mp 3's
thanks in advance
Bubba
Old Jun 16, 2007 | 08:13 AM
WhëëlMå1's Avatar
WhëëlMå1
Welcome to FTE. Are you talking about the bitrate of purchased cds? If so, it is a bit of an apples/orange example. The MP3 format is not a true "lossless" format. You cannot get the same quality of a cd, out of an mp3 file. With that said, the closest you are going to get would be to rip at 320+kbps.... but that kind of defeats the purpose of the format, because those files will be huge.
Old Jun 16, 2007 | 09:52 AM
bridge's Avatar
bridge
Sick 'n Tired
I think he wants to know what bit rate to burn his CDs at, some players won't play the lossless formats. The manual does not say, but the stock systems not good enough to realize the diff between 128 and 320. I doubt you'll be able to tell the difference between a 128 file and a 192, but 192 is probably optimum and won't give alot of compression artifacts.
Old Jun 16, 2007 | 12:18 PM
HEARTBEATTHIS
bridge, you are correct. i want to burn my disk to mp3 file. what do you suggest i try first?
Old Jun 16, 2007 | 12:36 PM
bridge's Avatar
bridge
Sick 'n Tired
Burn your CD to your computer at the highest possible bit rate then make your mp3 CD for your truck at 192kps.
Old Jun 16, 2007 | 06:17 PM
VFR_Man's Avatar
VFR_Man
I burn mine using VBR (variable), and the player in my 07 has had no problem.
