f100 bed Ques ?
Old Jun 15, 2007 | 11:08 AM
johnnyfaas's Avatar
johnnyfaas
f100 bed Ques ?
Will the bed on my 1964 f100 stepside fit on a 1956 f100 ,the 56 has the rear fenders just no bed ?
Also any links to 53 - 56 parts ?
Old Jun 15, 2007 | 11:45 AM
Randy Jack's Avatar
Randy Jack
It is my understanding that the stepside bed was the same up thru 72 EXCEPT that the fender mounting holes are higher on the side of the 64 bed than the 56 bed. You would need to move the attach holes down about 2-3 inches to properly mount the fenders to match up with the 56 running boards.
The best list of vendors for our trucks is on "Earl's World", a site by one of our members. It is also great reading for the rebuilding process. Enjoy.
http://www.clubfte.com/users/earl/index.html
And welcome to FTE!
Old Jun 15, 2007 | 12:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F100
Rear fenders 1953/56 = BAAA-16312-A R/S / BAAA-16313-A L/S. In 1957, Ford replaced the 1953/56 rear fenders with the 1957 rear fenders: B7C-16312-A R/S / B7C-16313-A L/S. These fenders were used thru 1979.
Bed sides went thru the same transformation. The original bed sides were: BAAA-8327840-A R/S / BAAA-8327841-A L/S. These were replaced by 1957 bedsides = B7C-8327840-A R/S / B7C-8327841-A L/S. These same bedsides were used thru 1979.
Tailgate: Original = BAAA-8340700-A was replaced in 1957 with B7C-8340700-A. It was used thru 1979.
All these beds look identical, and all will interchange: 1953 thru 1979.
Stepside? Grrrr...it's a FLARESIDE.
A Stepside is a Chevrolet!
Old Jun 15, 2007 | 04:46 PM
Scot's Avatar
Scot
Randy is right. The fenders moved up about 2" in '57. You can make it work if you weld up all the holes. The bed sides listed in the catalogs now are not pre-drilled.
Old Jun 15, 2007 | 06:39 PM
johnnyfaas's Avatar
johnnyfaas
Cool thanks all, any other parts Interchangeable ?
Old Jun 17, 2007 | 09:17 PM
abe's Avatar
abe
Randy is correct. Number Dummy has all the numbers. The bed sides are identical, except the fenders are mounted about 2 inches higher 1957 and up. I found this out the hard way. Bought a used bed with nice fenders from a 1971 pickup. Body man had a hard time getting the running boards on. He got them on but thay are cocked. I didn't realize it until I got the truck home and in the driveway and thought I saw a lot of tire. I measured the distance from the fender to the flare and went to measure my old bedsides and then I knew! The casual observer doesn;t notice it and I want to fix it with new bedsides in a few years!!
Look in my gallery to see what it looks like....
Old Jun 19, 2007 | 07:40 PM
barbsbuddy's Avatar
barbsbuddy
Do your rear fenders need any work? I needed to repair the lower front corners on my fenders and I had a '57 era bed. I added the extra length required in the front to get the fender down to the running board level I think the Mid 50s catalog says this measurement is 1 1/4". It does not look out of place and with a lowered truck the wheel looks good in the opening. It may be easier to extend the front of the fender than it would be to weld all of the holes and redrill them.
Old Jun 19, 2007 | 11:20 PM
johnnyfaas's Avatar
johnnyfaas
Ok I posted new pics of the 56 in the pic galleries.
The 56 has a 390 /auto with a clean title. The 64 has a 1968 428 cobra jet motor /trans/ rear but no title. I can always get new bed panels for the 56, and put the CJ in the 56 ?
Old Jun 20, 2007 | 03:17 PM
johnnyfaas's Avatar
johnnyfaas
How does the 56 look in the pics ?
