Another exhaust question
Old Jun 15, 2007 | 10:42 AM
pepito113's Avatar
pepito113
Exclamation Another exhaust question
Hello everyone. I have a 07 5.4 and was thinking about putting true duals all the way back. I have thinking about using magnaw flow for performance and not as loud. Also I have been reading and some people say that true duals will make you lose torque? Or about using a H pipe?? Also by doing true duals will there be enough back pressure and not make the check engine light turn on? If I wrote anything incorrect let me know. Any info and advise. please help.
Old Jun 15, 2007 | 01:45 PM
fearthedeere69's Avatar
fearthedeere69
true duals will not rob you of power as long as you dont go to big 2.25 duals should be good, a Hpipe will help with low end torque and will also quiet it down a little, backpressure should be a concern as you need none
Old Jun 15, 2007 | 03:06 PM
pepito113's Avatar
pepito113
So True duals should be ok. I want the power. But I heard you can lose low end torque. Has anyone put duals all the way on the 5.4. I am also worried about the check engine light. What does a h pipe do?
Old Jun 15, 2007 | 05:43 PM
1979FordF-250's Avatar
1979FordF-250
If your worried about loseing low end power than you can go with a single in dual out muffler.
Old Jun 15, 2007 | 08:35 PM
pepito113's Avatar
pepito113
Well I want the power. But why do u loose low end torque with duals?
Old Jun 15, 2007 | 09:39 PM
paul812's Avatar
paul812
i'm not sure of the reason of loss , if any, of low end torque but you asked about the H pipe...its there for balancing or equilizing the exhaust flow. (from side to side) ... paul...BTW...you prob. wont notice much diff in true duals in todays trucks. I'd just go with SIDO.
Old Jun 15, 2007 | 10:22 PM
pepito113's Avatar
pepito113
ok. I just want to add some kick to the truck. Thanks for the info
Old Jun 16, 2007 | 12:46 AM
Dustin1690's Avatar
Dustin1690
I really dont see how dual exhaust out the rear robs you off low end torque if anything its probably increased it for my on my 1993
Old Jun 16, 2007 | 12:55 AM
1979FordF-250
True duals lack the backpressure that is supposed to help low end torque.
Old Jun 16, 2007 | 08:14 AM
pepito113's Avatar
pepito113
Do u get more in cabin noise with exhaust pipes coming out the rear or both pipes to the side behind the rear wheel?
Old Jun 16, 2007 | 10:39 AM
1979FordF-250
If the windows are down then you would be able to hear the ones coming out the sides better, but if the windows are up then you hear the muffler itself mostly.
Old Jun 16, 2007 | 03:49 PM
mustangz_04's Avatar
mustangz_04
true duals will make you lose low end torque. They decrease back pressure. Our 5.4 motor LIVES in the lower RPMs to make its 365lb ft of torque.
Go with a single input dual out muffler. Flowmaster will lose the most torque. But I just installed a flowmaster 40 on my truck, it sounds great and I cant tell the torque difference.
