no wipers
Old Jun 15, 2007 | 04:31 AM
panteramatt's Avatar
panteramatt
no wipers
When I turn on my wipers in my 93 I hear a clicking coming from the passenger kick panel and nothing happens. How can I fix them?
Old Jun 15, 2007 | 07:30 AM
puck1263's Avatar
puck1263
The clicking is your wiper relay. That means your switch is working, and almost surely the relay is working. The only things left are the motor, ground and wiring between. I suggest you check for voltage and ground at the motor. If no voltage, check for wiring problem between relay and motor. If voltage is present, check the ground. If you've determined grounding is good but motor doesn't operate, replace motor.
Old Jun 15, 2007 | 05:37 PM
panteramatt
My haynes manual shows theres a ground wire on a stud but theres no wire on mine.
Old Jun 16, 2007 | 09:14 AM
Talyn's Avatar
Talyn
There is a ground wire on the 91 and older, i know this for sure. But its behind the light switch on the older ones. its in the glovebox on the 92 and up.
Old Jun 16, 2007 | 09:17 AM
panteramatt
That explains it.
