To Chip . . . Or?
Can the chip be programmed for towing/highway options? What real gains should I anticipate from the chip (HP, fuel mileage, enhanced performance due to programming for modified components)? Am I better off installing a shift kit? Anyone experienced with these areas are welcome to reply (
no speeches about the environment necessary - just looking for the best performance & mileage).The Diablo "Delta" takes the flip-chip concept one step further:
3 settings: 2 programmed codes and stock
Its due in February/early March.
If you're just looking for shifting improvements, by all means go with a shift kit instead of a chip and save your $$$. If you want the added performance of the chip along with shifting improvements then consider if higher octane is worth it, or if you want a flip chip, consider how many miles you drive and how long it will take to recover the gas difference.
What kind of mileage do you get and what's the average fuel cost in your area, both for 87 and 93? Let me know and I'll calculate the $$$ difference and how many miles you'll need to drive to break even.
Also note that we can't program a custom application with the cats removed unless you plan to use it for off-road applications, only standard code. (The EPA has busted diesel shops for doing that!)
