does anyone know the stock idle rpm's? i know you shouldn't have to adjust it, but the previous owner did to compensate for bad sensors i've replaced and need to get it idling correctly.
When it's idling, you are supposed to be able to unplug the IAC motor, and the engine should slowly lose rpm and die.
If it keeps running, the idle is set too high. If it dies right away, the the idle stop is not turned in far enough.
You may want to tear the whole throttle body apart and clean it up, and the IAC passages, before trying to set it. Fuel injected engines are famous for the throttle body getting gummed up.
I tried it today...took apart the throttle body assembly, cleaned all the gunk out, replaced the IAC, and reset everything per Gaknar's post...worked like a charm...truck runs brand new. Or maybe it's just the beer.....
Memory, experiance, and just a general understanding of how the system works.
I have read several diferant ways of doing it, thats the one that works the best in my experiance.
Sounds like setting it that way leaves 40 rpm of control to the IAC. I wonder what is the total rpm range of the IAC? The worst case on the other side of the range is fast idle at cold start.
Thats correct.
Ford shop manuals say to set the base idle at 400rpm. I have found that in the real world setting it at 600rpm gives a little stall coushion to these older vehichles.
Thanks for the replies, sorry I haven't replied back sooner(working 2 jobs leaves no time). I will give this a try once I get my hands on a tach and let you know how it works out for me.
