Computer Chips & Tuners
microtuner / tire size
Old Mar 25, 2002 | 08:19 PM
usmc1775's Avatar
usmc1775
I asked about after market tires and the mircotuner, I was told that you could not use after market tires, but what if you have ford recall your truck for the tires, then used the microtuner? Would that work? thanks for all your help.
usmc1775
2001 PSD 4x4 CC
Old Mar 27, 2002 | 11:46 PM
FTE Ken's Avatar
FTE Ken
You can use aftermarket tires with the chip..... you just can't just a different size and have the speedo correct and the shift points in the right place. The only way to insure this is either have the stock computer recalibrated for the different tire or the calibration done with a chip.
Old Mar 27, 2002 | 11:57 PM
FTE Ken's Avatar
FTE Ken
