Whats this for?
Old Jun 14, 2007 | 04:34 PM
Superdudey's Avatar
Superdudey
i paid 140$. was listed at 180 but i chewed him down 40$. It was all new, in the bag never used with a new map senser and filter minder
Old Jun 14, 2007 | 04:58 PM
OZX1's Avatar
OZX1
here's one...
Originally Posted by dchestnut
Enorma, what did you pay for the stock unit on E-Bay? I'm asking because I'm in the same predicament. I bought an '06 and it has an Airaid intake, but I'd rather have stock as well.
Thanks in advance!
Dan
2006 ford f 350 f350 stock air intake unit - $35
<hr> Reply to: sale-347083756@craigslist.org
Date: 2007-06-07, 12:46PM PDT
2006 f350 powerstroke stock air intake system, 2,500 miles on it
Bought a Banks unit 760-720-1456 <table summary="craigslist hosted images"> <tbody><tr><td align="center"></td> <td align="center"></td></tr> <tr><td align="center">
</td></tr> </tbody></table>
  • it's NOT ok to contact this poster with services or other commercial interests
PostingID: 347083756
Old Jun 14, 2007 | 05:00 PM
topnc's Avatar
topnc
Leave the airaid system on. flows much more air than stock one
Old Jun 14, 2007 | 05:10 PM
OZX1's Avatar
OZX1
Not bad for your second post
Ah! I see you no nothing of the warranty implications and the fact that your turbo is at risk... It's overwhelming opinion in here that the stock intake is the best solution, but feel free to use whatever intake solution you wish (and prematurely end your trucks life). Welcome to FTE. This place is stuffed full of information, so stick around.
It looks like you have a 7.3L F250??
Old Jun 14, 2007 | 05:15 PM
Enomra's Avatar
Enomra
Yes the Donaldson's flow so well that they even make an aftermarket one for the 7.3 now.
Old Jun 23, 2007 | 02:18 PM
blackhat620's Avatar
blackhat620
The OEM Donaldson air intake flows More air than the 6.0 can use until you get to 500+RWHP. So the only benefit of any A/M air intake on a 6.0 making 500RWHP or less is a dusted turbo and warranty denial. Use all A/M air intakes at your own risk.
Old Jun 23, 2007 | 06:58 PM
darsey715's Avatar
darsey715
don't let blackhat scare you guys. An aftermarket intake system doesn't ALWAYS mean a dusted turbo. When I bought my truck it had 41k on it and now has 73k. It came with an airaid intake and who knows how long it was used before I bought it. When I purchased it the airaid filter was clean if not brand new. didn't ask. When my turbo was pulled out to have it cleaned the 7 intake impellers looked just fine with absolutely NO chips, dings, scratches or excessive carbon build up. Also, not all dealerships will void warranty if you run one. The tech that cleaned my turbo works at a dealership south of morgan hill and told me if anything comes up that he will have his service manager cover it under warranty because he knows I don't beat my truck up or race it. It's all about finding a good match. they are out there. Just to keep things on an even keel(sp) around here. lol
Old Jun 23, 2007 | 07:17 PM
blackhat620
Well to flow more air you have to decrease the filtration ability of the filter by using larger holes in the filter media. This is a basic rule of airflow. Also dusted turbos and excessive engine wear do to increased dirt ingestion do not show up overnight. Best way to see the difference in filtration ability between OEM Donaldson system and A/M air intakes systems is by UOA, the Silicone levels will be higher with increased dirt ingestion.
As i stated before use A/M air intakes at your own risk, as there is no performance benefit to the motor, "caveat epmtor".
Old Jun 23, 2007 | 07:32 PM
WishIhada7.3's Avatar
WishIhada7.3
some of em are geting away with 98-99 percent filteration due to the fact the filter is HUGE and has alot of surface area....
Old Jun 23, 2007 | 07:37 PM
blackhat620
Is the filter bigger and have more surface area than the OEM Donaldson. The only way to increase airflow and maintain filtration is to increase the size of the filter area. All of the A/M air filters i have seen for the 6.0 use the same size filter box & filter as the OEM Donaldson system, the A/M air filters are not increase surface area in comparison to the OEM Donaldson system.
Also if the OEM Donaldson system flows more air than the 6.0 can use until you reach 500+RWHP what is the benefit of and A/M air intake?
The guys racing them have found no benefit in an A/M air intake until they reach 500+RWHP.
Old Jun 23, 2007 | 08:57 PM
darsey715's Avatar
darsey715
I like it because it flows more air and makes my turbo sound louder aka more whistle. sole reason I use it. and in theory it should help with mpg's. but ehh'.
Old Jun 23, 2007 | 11:23 PM
kmg99's Avatar
kmg99
Back to the original question, the hose is a secondary inlet in case the primary filter inlet is plugged, most likely by snow ingestion (which is an actual test run when developing a new vehicle).
Not sure how this ended up a discussion of air filters.
Old Jun 23, 2007 | 11:31 PM
  #28
blackhat620
Well the thread was about the air filter assembly, it got off on air filter elements in post #18 by newbie "topnc".
And yes the secondary inlet question and use was answered in the first few posts, look at post #6 by the BBC, for specific reference to secondary air inlet.
Old Jun 24, 2007 | 12:24 PM
  #29
Lonewolftx's Avatar
Lonewolftx
Wink Here you go . . .
There is a picture of where it goes in my BtLW Truckin' truck gallery. As you are holding it and where it goes into as well.
Old Jun 24, 2007 | 03:03 PM
  #30
a-rod's Avatar
a-rod
03-04 style rad support
05-07 new style rad support
