fuel consumption
Old Jun 13, 2007 | 11:48 AM
idifamilycab's Avatar
idifamilycab
Unhappy fuel consumption
seems as though my fuel milage has gone down. i think im only getting about ten mpg. 92 7.3 banks turbo crew cab dually. What can i do to improve mpg at least to 13? more would be nice though. Would love to fill my tank all the way and get an accurate reading but times are tough so i have to nickle and dime. Any help would be appreciated.
Old Jun 13, 2007 | 12:14 PM
PLC7.3's Avatar
PLC7.3
You must have 410 rear axle..... air filter maintenance and running good fuel with additives is the best fix. How old are the injectors and IP. How big is the exhaust system......3"...4"........ got a muffler on it still.
Old Jun 16, 2007 | 08:01 AM
idifamilycab
funny thing is i havent even figured out my gear ratio yet . have a k&n filter, banks 3" exhaust to muffler then 3 1/2" out after muffler. dont know about the injectors or ip pump. Ive had the truck for about 6 mos and i havent replaced them yet. if needing to replace injectors should i upgrade to a stage 1 or would a stock replacement be better.
Old Jun 16, 2007 | 08:05 AM
idifamilycab
also would you recommend changing gear ratio? how much take off will i lose? im running about ten lbs of boost thanks to dave S.
Old Jun 17, 2007 | 12:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Give me a little info,
What tranny do you have?
What RPM are you running at 60 MPH in high gear?
Actually I can figure it out as long as I know what gear and the RPM and speed in that gear.
Old Jun 17, 2007 | 10:24 PM
archangel's Avatar
archangel
Look on the tag attached to the rear axle cover.
The info is stamped right there.
Old Jun 18, 2007 | 10:43 AM
shorthair's Avatar
shorthair
I'm well aware that fuel costs are waaaaaay up & they just are not going back to where they were BUT it costs exactly the same to keep the top 1/2 of the tank full as the bottem 1/2 plus if you choose to check MPG it can be done on the top. that said you might try burning FILTERED WMO for a while 50% to even 100% fi the weather is warm it sure cuts the total cost of fuel down.
Old Jun 18, 2007 | 02:46 PM
BUZZer67's Avatar
BUZZer67
OK, call me ignorant,, but what is WMO?
(Waste Motor Oil???)
Old Jun 18, 2007 | 05:47 PM
CheaperJeeper's Avatar
CheaperJeeper
That's it. Some people do it and say they have no problems - some people have wasted their pump & injectors doing it too.
Keep in mind, you can filter it finely enough to get the metals and most of the soot out of it, but no matter how finely you filter it, you can't get rid of the acids and such....
Old Jun 20, 2007 | 12:26 PM
idifamilycab
ok so i finally made a mental note....cruising at 60mph tach reads about 2100rpm also e40d (just added that to my signature) tires are 235-85-16
Old Jun 20, 2007 | 04:30 PM
shorthair's Avatar
shorthair
my trucks pump is finally on her last legs so she'll be getting a new one this month, new delphi nozzels too, the savings from burning WMO has paid for 'em several times over, plus it looks like there is 218,000 on the original nozzels so they are well past due.
Old Jun 20, 2007 | 04:32 PM
Dave Sponaugle
235/85-16 tires and 2100 RPM with an E4OD tranny in overdrive at 60 MPH works out to 4.56 gears.
Old Jun 21, 2007 | 05:42 PM
idifamilycab
is 4.56 stock for this truck? It still has the axle tag on the diff cover. Finally looked at it and wrote it down V170D 10 10 2 2B19. Can you translate this for me anybody? i actually wouldnt mind down sizing to try and gain a little top end and gain a little better fuel milage. Bottom end im not so worried about because i dont really tow much and that travel trailer sits for periods at a time. Just dont want it to be a total dog off the line.
Old Jun 21, 2007 | 07:50 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Look on the vehicle certification label. Which should be on the drivers door jam. It should say what the rear axle code came with the vehicle.
Old Jun 21, 2007 | 09:07 PM
Dave Sponaugle
The bottom line of the tag starts with the ratio.
If you see 10 as the first numbers it is an open 4.10 gear, the bolt covers the first number.
If you see L10 you have a limited slip 4.10 gear.
4.56 was not a common ratio, but you could special order different ratios.
4.10 or 3.55 are the two most common ratios out there.
