Help Staying Hydrated
Old Jun 14, 2007 | 01:50 PM
Aztrainer's Avatar
Aztrainer
Originally Posted by Ford51
Watch out rebocardo, full strength gatorade is already extremely high in sugars and sodium. Adding more can be dangerous. A lot of people think its logical to be replacing all of those nutrients but the high amount of sodium can be bad.
So true
You body works on something called the sodium/potassium pump. When an electrical signal is sent down the muscle fiber it will cause a depolarization of the nerve in which the sodium and potassium ions switch places. If you have too much sodium then you will cramp-up and the same is true if you have too much potassium (Very unlikely).
Watch the amount of sodium you ingest in a day, because it is a diuretic and thus will cause you to excrete more water.
Old Jun 14, 2007 | 05:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by woogs
what is Endurox R4?thanks-matt
Endurox R4 is a technologically advanced sports drink based on this new model. In three clinical trials the researchers found, compared to Gatorade, Endurox R4: Enhanced performance and extended endurance by 55% Reduced free radical buildup by 69% Increased muscle glycogen replenishment by 220% Reduced post exercise muscle damage by 36% The patented Endurox R4 formula includes electrolytes, high glycemic carbohydrates and whey protein in a 4:1 ratio (Optimal Recovery Ratio), arginine, antioxidant vitamins E and C, glutamine, branched chain amino acids and the natural herb, ciwujia. Endurox R4 is a total nutritional approach to muscle performance and recovery because it is specifically designed to: Restore electrolytes and water. Replenish glycogen stores rapidly. Reduce muscle and oxidative stress. Rebuild muscle protein. The results of the clinical trials provide powerful support that Endurox R4, by improving muscle performance and enhancing recovery, should be the product of choice for any athlete engaged in aerobic activities such as running, biking or swimming or team sports such as basketball, football or soccer.
Each serving contains: Calories 280 Calories From Fat 15 Total Fat 1.5g 2%* Saturated Fat 0.5g 2% Cholesterol 10mg 3% Total Carbohydrate 53g 18%* Sugars 30g ** Protein 14g 28%* Vitamin C 470mg 780% Vitamin E 400 I.U. 1330% Calcium 100mg 10% Iron 1.8mg 10% Magnesium 250mg 65% Chloride 270mg 8% Sodium 230mg 10% Potassium 140mg 4% Ciwujia (Endurox®) 600mg Standardized Root Extract ** L-Glutamine 2560mg ** Branched Chain Amino Acids 2719mg ** L-Arginine 1527mg
Other Ingredients: Glucose, Complex Carbohydrates, Whey Protein Concentrate, Crystalline Fructose, Citric Acid, L-Arginine, Natural Flavors, Ciwujia, D-Alpha Tocopheryl Acetate, Ascorbic Acid, Sodium Chloride, Citric Acid, L-Glutamine, Magnesium Oxide, Paprika (natural color), Potassium Phosphate, Lecithin.
Old Jun 14, 2007 | 05:26 PM
websthes's Avatar
websthes
Just do what i do go and sit in the shade for a few minutes.
Old Jun 14, 2007 | 06:20 PM
jgc2521's Avatar
jgc2521
a tip for when you wash your face etc...
mix a cooler of water and a little bit of ice and a bottle of cheap cologne. this will cause your pours to open and cool you off fast. at school we called it florida water... it works good. just soak a rag in it, wipe your arms your head, neck, and face and your good to go.
Old Jun 14, 2007 | 08:21 PM
jroehl's Avatar
jroehl
On the really hot days, when I take a water break, I will dribble a little of that water down the back of my neck. It almost feels like you jumped in an icebath. I got that from watching the marathons on TV--you'll see the runners take a gulp of water from a cup then toss the rest on the back of their neck.
A banana and an apple during the day help, too, and I've found I can recover better from a strenuous day if I drink a whey protein mixture here and there, like one at lunch and one at the end of the day.
Jason
Old Jun 14, 2007 | 08:36 PM
F350-6's Avatar
F350-6
Gatorade will help with electrolytes, but if you're really worried about dehydration you have to keep your body hydrated, not just when you're at work. Cut back on caffeine, and work on hydrating your body at night and on the weekends. Then just try to keep the fluids up during work. You can't play catch up without stopping and taking a several hour break. You have to start the day in the right condition. When I was in the Marines we were told it takes about 3 days of drinking lots of water to get your body hydrated, then you have to maintain that as you sweat.
Old Jun 14, 2007 | 10:47 PM
woogs's Avatar
woogs
thanks Admin. that was deff. more than I was looking for, but much apreciated.
I tried washing my arms/neck/face in cool water and felt great, I'll deff. keep doing that. Also I'll be drinking more water while I'm resting in the evening/morning.
I've never heard of a cooler bandana that welders wear. what is that and where do you go about getting one? Grainger or Fastenal maybe?
I do have plenty of regular bandanas I used to soak and wear around my neck backpacking.
jgc do you end of smelling like cologne all day? I guess it's better than how I smell though.
thanks
-matt
*EDIT*
Aztrainer: "Watch the amount of sodium you ingest in a day, because it is a diuretic and thus will cause you to excrete more water."
I did wake up pretty loose this morning. I'll dilute the gatorade a little more tomorrow and try that.
Old Jun 15, 2007 | 12:51 PM
Aztrainer's Avatar
Aztrainer
Woogs
If you have a lot of bandanas you can do this as a little trick I do for the start of football season here in hell err.....Arizona with 110 degrees. Get a small cooler and put ice then bandanas and put water. Let it sit for a little while and put one on the back of your neck over the carotid artery. Change them out every thirty to forty minutes and put the old one back into the cooler. This is a trick that will keep you surprisingly cool in very hot temperatures.
Old Jun 15, 2007 | 05:07 PM
jgc2521's Avatar
jgc2521
no, well i mean we were playing football... but no. someone told me it was the alcohol in the cologne that opened the pores. idk, maybe spike your rand with a little alcohol? You dont really have to use a bunch, We filled up a biggo water thing with it. maybe feel up a old milk jug or somethin and pour a lil bit in it. if you want ill ask s/o and find out for sure... hows that sound?
Old Jun 15, 2007 | 05:11 PM
lariat97's Avatar
lariat97
Thanks for the Endurox R4 info. I will try it. I spend too much time in the heat & this stuff sounds like a great way to rehydrate.
Old Jun 15, 2007 | 05:37 PM
IB Tim's Avatar
IB Tim
I ride about 500/800 miles a month, with a number of medical challenges my hydration is very critical, the more water you drink the worse you make dehydration without a total electrolyte balance, you wash away what you need.
I hate to say it Gatorade is only …..at best…. half of what you need. Might be hard to believe but few athletes ever drink Gatorade. I am talking endurance type athletes or competing at a very high level of competition.
The problems becomes when people only add sodium, you need all five substances to balance hydration, when you get all supplied you will never have cramps, or be dehydrated. The good thing is it helps digestion and stomach/intestinal cramps also, a precursor that takes place LONG before muscle cramps show their ugly face. Most right it off to bad Taco bell.
Trust me I have a team of doctors and a coach that has taken a ton of data off me to figure all this out.....
Use the R4 all the time not just to re-hydrate....that is where we have learned so much.....pre balance saves …………
Old Jun 16, 2007 | 03:05 PM
rebocardo's Avatar
rebocardo
Well, they had a police recruit in GA (?) that actually killed himself by drinking too much water! Only cramps I usually get are hands or feet while working then maybe cramps at night in the legs though I usually head that off by not raising my legs right away to sleep if I am very tired.
I wouldn't recommend wearing perfume/colgne to anyone in the southern woods unless you like getting eaten or attacked by yellow jackets.
A -moderate- amount of salt helps me, especially since I usually do not eat much while working, but, still lose 2-3 pounds sweating. Someone said eating pickles would help, they do. I think it is all the salt though I admit not knowing what all that vinegar does combined with the corn syrup most pickles have...
Endurox R4 sounds good though I would have to see what the roots and stuff like arginine and Ciwujia are.
Old Jun 16, 2007 | 04:34 PM
  #28
Aztrainer's Avatar
Aztrainer
Yes, you can drink too much water and your blood becomes too thin due to hyperhydration. It is called hyponatremia in which there is not enough sodium in the system.
Pickels have sodium in them and thus they make you feel better and there is a item called "Pickle Juice" that is being touted as a replacement for poweraide and gatoraide
http://www.goldenpicklejuice.com/
Old Jun 17, 2007 | 10:34 PM
  #29
ken's 80's Avatar
ken's 80
Similar to what Ford51 stated, I drank about TWO gallons of GATORADE a day when I built my garage. The temps were in the 90's and 100's and it took me nearly one month to complete the whole job.
I went to my physician for a regular checkup during that time period and they thought something was wrong with me because my electroylte level was SO high.
I then told them about the GATORADE consumption and that eased their (and my) minds.
Old Jun 18, 2007 | 12:42 PM
  #30
00BlueOvalRanger's Avatar
00BlueOvalRanger
I don't know about adding BOILING water to powdered Gatorade to mix it, but, I do use hot water from the tap, to mix.
Just the heat from the water will start breaking down the solids, so they mix better. (Goes for any powdered drink mix, like Nestea; Lipton's, etc.)
I've found that eating a small portion of fruit (1/2 banana or 1/2 an apple, or 4 or 5 strawberries) helps a LOT when I'm really thirsty, along with the gatorade or drink water with LIME squeezed into it.
Another trick instead of cheap cologne(s), etc., is to use Isopropyl alcohol and water mixed, and rub this on your arms and neck.
The Isopropyl makes the water "Wetter" (printer's trick) and will also help open the pores to let heat escape and to cool your body down.
(Necessary caution- - - - do NOT injest the water/alcohol mix!!!)
Also, a rub down with 'Sea Breeze' will help to cool down your body.
