Sponsored by: Auxito
7700 Question
Old Jun 12, 2007 | 10:24 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
7700 Question
Dual gas tanks? Or what?
Old Jun 12, 2007 | 10:26 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Upon further research...I found out it's for CNG. What is that?
*EDIT*
Ok...I did a little more research:
http://www.indiacar.com/infobank/using_cng.htm
Sounds interesting. Has anyone run it? And what do you think about it?
Old Jun 12, 2007 | 10:32 PM
galaxie641's Avatar
galaxie641
Natural gas. Did you just find this truck on the street and open the doors up and take a pic?
Old Jun 12, 2007 | 10:37 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yeah
I was searching google for a pic for one for the SD forums when I came across this and thought WTF?
Old Jun 12, 2007 | 10:43 PM
rsylvstr's Avatar
rsylvstr
dual fuel.
CNG and gas.
CNG sucks.
i had a 7700 at work, 2WD, regular cab and i was lucky to get 9 MPG.
Old Jan 20, 2008 | 10:14 PM
darress's Avatar
darress
At 9 mpg something was wrong with your truck. I have a 2001 F 150 7700 4x4 extended cab with a camper shell and the bi fuel set up (gas or cng). I get about 13 mpg on either fuel doing 75+ on the freeway. Not to mention here in Utah the cng is only 64 cents per gallon. Nope, cng doesn't suck for me.
Old Jan 20, 2008 | 10:18 PM
rsylvstr's Avatar
rsylvstr
it was a straight up CNG truck....and the 9mpg could be due to the fact that i'd do the typical state thing, let it idle all day LOL.
Old Jun 7, 2008 | 09:29 AM
websltd's Avatar
websltd
i have the b 7700 runs great on gas but very rough on cng
Old Jun 7, 2008 | 11:07 PM
darress's Avatar
darress
Check out cngchat.com and go to the Ford section. Look specifically at the posts on replacing the coalescent filter and doing a tune up with cng injector o-rings, coil packs, and plugs. Lots of info there and feel free to email me as well if you have questions. Mine was rough on cng before addressing the above stuff, great now. Hope that helps.
aldridgec
1997 - 2003 F150
Oct 16, 2025 11:34 AM
xgreg27x
1997 - 2003 F150
Apr 26, 2012 08:47 PM
nut1605
1997 - 2003 F150
Nov 2, 2006 10:41 PM
Custom Junk
Aug 1, 2002 07:43 PM
disaacs
1997 - 2003 F150
Jun 16, 2002 02:04 PM
