Shudder problems
Old Jun 12, 2007 | 11:46 AM
subford's Avatar
subford
Shudder problems
I have a 1995 F150 5.0 A/C 4R70W with a shudder problem.
It happens at 1500 RPM while driving or parked.
Take the serpentine belt off and no shudder at 1500 RPM.
Replaced fan clutch and that did not change it at all.
Engine idles very smooth with no shudder until you raise the RPM and then the bad shudder at 1500 RPM, above this RPM the engine is smooth again.
I am thinking Air Pump, does anybody have any other thoughts.
Old Jun 12, 2007 | 11:55 AM
quicklook2's Avatar
quicklook2
water pump?
with belt off try moving it on its axis.
does air pump seem loose or making any noise?
Old Jun 12, 2007 | 12:08 PM
subford's Avatar
subford
Originally Posted by quicklook2
water pump?
could be, it does squeak when you turn it.
No, not that I know of but it does have a lot of fan noise.
Old Jun 12, 2007 | 12:10 PM
Skandocious's Avatar
Skandocious
Yeah I would follow quicklook's procedure for all of the pulleys. Move them up/down and side-to-side. Any that have a lot of play could be your culprit.
Does it do it with both the A/C on and off? ie, the A/C clutch both engaged and disengaged.
-Chris
Old Jun 12, 2007 | 12:15 PM
quicklook2's Avatar
quicklook2
my bearing went bad in my water pump and the belt started moving front and back a little on the w.p. pulley.
had a strange vibration if i remember right.
Old Jun 12, 2007 | 12:16 PM
Skandocious
Could also be a weak spring on your tensioner (depending on how bad the shake is), although that would typically cause a vibration at lower RPMs if I remember correctly...
-Chris
Old Jun 12, 2007 | 12:23 PM
subford's Avatar
subford
Thanks, I will look at it in a day or two, I have to work on a BII and a Ranger today.
POS Camaro
Oct 13, 2015 08:19 PM
Mat523
Jun 25, 2015 04:31 PM
kdv
45
Nov 22, 2010 06:09 PM
masseysbronco
Jun 3, 2010 04:56 PM
Red03XLT
2004 - 2008 F150
Sep 21, 2005 04:53 PM
