Master cyl venting question
Old Jun 12, 2007 | 10:25 AM
brider's Avatar
brider
It occurred to me as I was about to replace the M/C on my '66, that there is NO vent at all in the top screw-cap, unlike more modern M/C caps that are vented.
So how does the brake system allow for pad wear or excessive pedal travel (brakes out of adjustment) without causing a vacuum in the M/C itself?
Old Jun 12, 2007 | 10:45 AM
norvillebob's Avatar
norvillebob
The rubber boot just collapses under the lid.???
bob
Old Jun 12, 2007 | 01:00 PM
brider's Avatar
brider
Never thought of that, does the big screw-on cap on my '66 HAVE a rubber boot? Then the boot would have to be vented, also, and I just don't see a vent...
Old Jun 12, 2007 | 01:05 PM
norvillebob
HMM ya know what I was thinking dual chambered. That was the first mod I did from a 68 with Drum/drum.
bob
Old Jun 12, 2007 | 02:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What "modern" master cylinder cap is vented?
Old Jun 12, 2007 | 02:56 PM
airharley's Avatar
airharley
Bill they are refering to the air gap that exists between the rubber gasket and the cover assembly.
For the single master cylinders there is only a pin hole near or under the retaining clip or for screw ons almost dead center of the cap. Dual masters have what looks like a pinch mark in the metal cap over each side of the reservoirs.
Old Jun 13, 2007 | 07:07 AM
brider's Avatar
brider
The reason I focused on the "venting" is because I have an older non-Ford truck with dual-chambered master cyl, and the (2) separate chambers have obvious vent holes in the caps. Makes obvious sense; if the fluid level changes (whether by actuation or pad wear), AIR has to take up the space, or a vacuum will occur.So the old screw-on cap IS vented? Good enough for me.
Old Jun 15, 2007 | 10:36 PM
William's Avatar
William
Can't hurt, just drill a small hole in it!
prndl
1961 - 1963 F100 Unibody
Dec 27, 2012 06:14 PM
kilog55
Aug 12, 2009 08:13 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Nov 14, 2006 06:23 PM
phjbbu
Jul 5, 2002 11:23 AM
Trail_Rider
Jan 6, 2000 12:23 PM
