88 to 86?
Old Jun 11, 2007 | 11:07 PM
'86_150's Avatar
'86_150
Unhappy 88 to 86?
hey, i just got in a wreck and totally screwed up my front end on my 1986 f-150 and i have an option to get a really cheap 1988 bronco and i was wondering if the front end of the bronco will swap easily onto my 86 that includes axle and everything. Thanks much
Old Jun 12, 2007 | 09:16 AM
Franklin2's Avatar
Franklin2
The axle should. I am not sure about the frontend but I would try it. Just make sure you take the whole front clip, fenders, inner fenders, radiator support, etc. I haven't done it on these trucks, but Ihave done several cars, and the whole front sheetmetal comes off in one piece, minus the hood which comes off seperate.
Here's a link to Sycostang67's gallery were he did a bunch of body swapping.
https://www.ford-trucks.com/user_gal...&albumid=14619
Old Jun 12, 2007 | 09:53 AM
Sycostang67's Avatar
Sycostang67
Yeah it all bolts on as long as you take everything like dave said. Use the newer cowl panel too, it has smaller holes and will help stop leaves and junk from getting in.
Old Jun 17, 2007 | 09:27 PM
'86_150's Avatar
'86_150
Ok so i found a 89 bronco because the 88 fell through and all i need for the frontend is the passenger side monobeam. So i need to know if that monobeam will fit onto the driverside of the 86 side, if anybody knows if the spindle or anything is different which will set it off that would be great thanks!
