driver's door lock not working
Old Jun 11, 2007 | 09:52 PM
rbridges's Avatar
rbridges
I did a search and it seems that the actuators are prone to failure. I just want to see if my problem is consistent. It stopped working suddenly. No clicking, no sounds, nothing. Key works fine for manual opening/locking. The other 3 doors and hatch work fine, but the driver's door is silent. No sound whatsoever in the driver's door with the fob or the door switch. Also nothing when I use the passenger side switch.
Does that happen with actuators or should I look for something else?
Old Jun 12, 2007 | 12:26 PM
buzzard's Avatar
buzzard
Sounds like the actuator to me, I've had a couple replaced.
Old Jun 12, 2007 | 04:11 PM
jd111404's Avatar
jd111404
I have a problem with the passanger door. Sometimes it works sometimes not. It looks like it comes only half way up and if I keep hitting the button sometimes it will come up. I would like to get it fixed though but not sure what the problem is.
Old Jun 13, 2007 | 09:55 AM
buzzard's Avatar
buzzard
See reply above.
Old Jun 15, 2007 | 11:03 AM
rbridges's Avatar
rbridges
I found a write up for removal/replacement for an excursion. is the process similar in the expedition?
