Bronco II Ford Bronco II
axles
Old Jun 11, 2007 | 09:13 PM
bronco2man's Avatar
bronco2man
axles
am wondering if i have to change my axles in b2, am running 3.55 in it with a 5-speed, am upgrading to an a4ld that has axles with 3.73 gears, will my b2 run slower if i keep the 3.55's in it and bog the engine down or should i put the 3.73 axles in?
Old Jun 11, 2007 | 10:57 PM
kernel-panic's Avatar
kernel-panic
Your current axles are more than likely 3.45:1, not 3.55 (unless you swapped in Ranger axles / gears -- http://therangerstation.com/tech_library/Axles.html). Automatics generally come with 3.73 or 4.10 gears in the axles to the best of my knowledge, and they would probably suit the A4LD better vice the current axle ratio. It may not affect your 3rd or overdrive speed much, but 1st and 2nd may not have the same performance or economy. Depending on what your intended use of the vehicle is, you could just opt for putting the 3.73 axles under there with the 5-speed for a little more power to the wheels if you intend to use it more for off-roading. If your sole purpose is to get rid of the manual transmission, then I would opt for doing the axle / gear swap as well. Personally, I wouldn't put an A4LD in, just because unless it has been rebuilt right with the newer beefier parts, it's just going to be more problem than it's worth, IMO. Just my $0.02, hope this helps.
turnkyle
May 17, 2011 05:09 PM
azsaluki
2009 - 2014 F150
Feb 8, 2011 08:37 PM
Milwaukee1979F150
Mar 18, 2010 02:39 AM
Mycopsycho
1997 - 2003 F150
20
Nov 6, 2006 05:55 AM
Toreador
2004 - 2008 F150
Jul 16, 2004 11:07 PM
