little nuisance
Old Jun 11, 2007 | 08:29 PM
spgivens24's Avatar
spgivens24
little nuisance
I have put a new cam in my 400 motor recently. Now when I drive it for a while and turn the truck off it won't start back up. It acts like the coil isn't getting any spark.(just turns over with no fire) The only way I can get it to start is to replace that little condensor on the negative side of the coil. I have rebuilt 400s and 351ms numerous times and never have run into this problem before.
Old Jun 11, 2007 | 09:12 PM
53fatfndr's Avatar
53fatfndr
You might want to recheck your timing.
Old Jun 12, 2007 | 08:39 PM
danlee's Avatar
danlee
Do you have a Ballast Resistor or a Resistor wire on the + side of the coil?
Old Jun 25, 2007 | 08:42 PM
spgivens24's Avatar
spgivens24
Resistor
All I have on the pos. side of the coil is the tach wire and one more wire. So I imagine that I have a Resistor wire.
Old Jun 26, 2007 | 06:11 AM
danlee's Avatar
danlee
Here is the wiring diagram for a Duraspark ignition. Check your wiring.
Old Jun 26, 2007 | 08:10 PM
spgivens24's Avatar
spgivens24
Thanks for the wiring diagram.
