2.5" Leveling Kit Installed Wrong
Old Jun 11, 2007 | 07:10 PM
FlameNSky's Avatar
FlameNSky
Hey I am wondering if you guys that have leveling kits on your trucks could shed some light.... I installed a 2.5" Leveling Kit from NCD Customs. When I had the alignment done, they said they couldn't get the caster and camber to 0 but got it "within" standards. I thought that it was odd because the product information said that only the toe in would be off. Now after a few days of driving, I noticed that my upper control arm is rubbing my springs. Both sides have a 1/8" groove in the spring now from the control arm. Has any one else had this problem with the control arm and spring making contact? Thanks for the replies!
Old Jun 11, 2007 | 07:25 PM
black04lariat's Avatar
black04lariat
I have the NCD as well. I have had it on for a while now and havent had any problems. As for the rubbing, I just went out and looked at my coil and on each side there is a minimal amt. of rubbing on one "rung"?? of the coils. Maybe enough to wear the paint off and it doesnt look fresh. I have had the kit on for 10k miles or so.
Old Jun 11, 2007 | 07:30 PM
NASSTY's Avatar
NASSTY
It shouldn't have affected the camber, Hmmmm?
I noticed the NCD spacer doesn't have the offset design like the AS to avoid rubbing. I also noticed that NCD has a 30 day satisfation gaurantee.You could try to get your money back if you're not happy with it.
