Engine squeeling after high idling or under load.
Old Jun 11, 2007 | 03:12 PM
REELNAUTI4U's Avatar
REELNAUTI4U
Question Engine squeeling after high idling or under load.
When truck has been high idling for say 10-15 minutes in hot weather and I leave it sounds like the engine fan is on and then when I accelarate it makes what seems to be a metal on metal squeeling or even a loose belt noise. I have also heard this noise when towing and fan comes on then if I accelarate the squeeling noise starts again. It does not make noise for long maybe 5-10 seconds. Any suggestions ?
Old Jun 11, 2007 | 09:32 PM
msgtg's Avatar
msgtg
Hmmm, I've let mine idle that long but I'm in WV...not exactly a hot weather haven, and have not experienced that kind of problem.
How many miles do you have on yours?
I've got an 03 F250 6.0 King Ranch crew cab, auto, 4x4, 3.73 16" wheels with 45K miles on it....no sunroof and mines Emerald Green w/tan.
Old Jun 11, 2007 | 10:29 PM
blackhat620's Avatar
blackhat620
It could be a bad belt, i believe there is a TSB out on this.
Old Jun 12, 2007 | 08:19 AM
REELNAUTI4U
How would I find a copy of this TSB ? I have called several dealers in the Houston area and inquired about this noise and they were dumbfounded. I also found this on another forum and it sound like the same problem.
Cat=0&Number=3377809&an=0&page=1#Post3377809
Old Jun 12, 2007 | 08:45 AM
a-rod's Avatar
a-rod
The belt on my truck had to be changed right after it was bought, I beleive for the same reason. Been good since.
Old Jun 12, 2007 | 02:29 PM
REELNAUTI4U
Does anyone else know where I can get a copy of the TSB for this issue ?
Old Jun 13, 2007 | 12:48 AM
2005 Ford's Avatar
2005 Ford
Go to the dieselmanns page. it has all the tsb's. this site also has them
Old Jun 13, 2007 | 11:02 PM
4mil's Avatar
4mil
Sounds like the electro-mechanical clutch to me. I have the same noise and am taking it in soon. Only happens when fan is partially engaged huh.
Old Jun 13, 2007 | 11:47 PM
Zip's Avatar
Zip
As posted above I would check the fan clutch.
Old Jun 15, 2007 | 09:58 AM
glsurratt's Avatar
glsurratt
I think I've got the same problem. I'm pulling 18,000 lbs of fifth wheel. When I get in the hills, here's what happens:
The truck downshifts.
The fan clutch kicks in.
As I get to the top of the hill, the truck shifts back into overdrive (5th).
The fan is still running.
Right before the fan stops, it sounds like an old-fashioned telephone ringing somewhere under the hood.
When the ringing stops, the fan clutch has disengaged.
This only happens when I'm running up and down hills with the trailer. The gauges never move to indicate any overheating condition or even a rise in temperature at all.
I'm thinking fan clutch or idler pulley?
