Gas Tank
Old Jun 11, 2007 | 03:52 AM
bryonwleeper22's Avatar
bryonwleeper22
Gas Tank
Stupid Question. Which is the Aux and which is the main tank? Front/ Rear?
Old Jun 11, 2007 | 04:10 AM
73f350sc's Avatar
73f350sc
If you do a search of this forum Im sure youll find the answer....on mine the aux. is the one in the bed closest to the cab and the main is the one way out back....but then again..mine has also most likely been switched around a bit from the removal of my seat tank...so it may be different on more stock truck.
-Chris
Old Jun 11, 2007 | 06:18 AM
bryonwleeper22
cool thanks, I know my front tank is bad and I just replace the back one. I would be pissed if I sucked that crap into my carb etc. Someone decided to bypass the lock and cut my filler hose to siphon. All this in the 2 years it sat before I got out the army and im sure seeing is how it was on the Oregon coast that its chalk full of moisture and crap!
Old Jun 12, 2007 | 09:41 AM
partsman01's Avatar
partsman01
Mine appears to be the rear is main and my side tank in my 77 is the Aux.
