Ignition Problem
Old Jun 10, 2007 | 05:54 PM
CommrclDiver's Avatar
CommrclDiver
Ignition Problem
I have a 1971 F-100 and I drove to the store this morning and when I got back the truck would not turn off. I finally had to pull the coil wire off to shut it down. Now I can't get it to start. Any ideas on the problem?
Old Jun 10, 2007 | 07:02 PM
Mil1ion's Avatar
Mil1ion
Ignition switch lead to coil wire.
Old Jun 10, 2007 | 07:11 PM
doug1222556's Avatar
doug1222556
I agree, but it sounds like the switch contacts have welded shut,so I would try to by-bass the ignition switch and see what happens, just a guess, what do I know?
Old Jun 12, 2007 | 01:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C0LF-12250-A .. Resistor (Hot) Wire (Motorcraft DY-37) 61.50" -long, No. 20 gauge wire, color coded pink
Old Jun 12, 2007 | 02:45 PM
Mil1ion's Avatar
Mil1ion
I'm thinking it's the ignition switch (positional thing) as they don't last forever.
When I mentioned coil wire..I meant to check that for power running thru it when key is in OFF position.
You see...the ignition switch is just a positional thing that diverts power from the battery to different circuits..one being the ignition system ( The coil )
Old Jun 12, 2007 | 04:56 PM
Red69's Avatar
Red69
I had the exact same problem on my 69. If you pulled the wire on the solenoid it would stop the engine. The trouble was in the alternator back feeding the ignition side of the solenoid. I had to have the alternator rebuilt and stator replaced.
