Speedometer and tire size
Old Jun 10, 2007 | 05:42 PM
Modified 99's Avatar
Modified 99
Smile Speedometer and tire size
I'm about to put 265/70/16 tires on my 99 Expy. The tires on it now are 255/70/16. It appears that there will be 10 less tire Revs per mile with the 265's. Does Ford offer a spedo gear to "Calibrate" the speedometer. How much will the spedo be off. It should show slower than actual speed, I think.
Any suggestions?
Old Jun 10, 2007 | 06:38 PM
outsdr2's Avatar
outsdr2
Hello yes it will be about 10 mph off.(slower) what alot of people do is buy the superchip with tire size calibration. a good way to tell correct speed is with a hand held gps.
Jack
Old Jun 10, 2007 | 09:59 PM
Johnny Langton's Avatar
Johnny Langton
Your speedometer will read approx 2mph less than actual speed with that minute change in tire diameter. You'll need to change the revs/mile in the EEC if you want to correct it-that'll require a tuner or chip to do so.There is no speedo gear to do this on the '99-up Trucks.
JL
Old Jun 11, 2007 | 10:03 AM
buzzard's Avatar
buzzard
Don't even worry about it as your size difference is negligible. I went from 30" to 33" which is 10% or 2 at 20, 5 at 50 or 7 at 70 and I've never had any problems.
Old Jun 17, 2007 | 06:52 AM
Modified 99
Talking
I had the tires installed the other day and compared the speedometer to a GPS. There was no difference. The Avon Ranger tires are WONDERFUL.
