56 Vin Plate orientation
Old Jun 10, 2007 | 02:34 PM
fergusonicford's Avatar
fergusonicford
I have to install the Vin Plate on my 56 F100 and I have a couple questions: 1) Is the Vin Plate positioned so that you read it from bottom to top thus having the "Ford" to the inside of the cab.......or is it oriented to read top to bottom?
2)By what means is the Vin Plate attached? Riveted? Screws? (phillips or straight)?
Old Jun 10, 2007 | 04:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The VIN plate rivets on the inside of the glove box door. When you open the door, the plate is readable. I've owned 3 1956 F100's, and all had the plate on the inside of the glove box door. There should already be holes there if the plate is missing.
Old Jun 10, 2007 | 07:43 PM
theGman's Avatar
theGman
Dittos on above. Should be in glove box, or manifest box, didn't they call it?
Old Jun 11, 2007 | 07:30 AM
9teen56f100's Avatar
9teen56f100
The 53-55 plate is on glove box door. The 56 is on the driver door post.
Brian...
Old Jun 11, 2007 | 07:53 AM
NumberDummy
Interesting, since I've owned three 1956's and all the plates were on the glove box door. The parts catalog says depending on model. I also believe that different assembly plants could have placed them in different locations. On San Jose built 1960's and 70's trucks, the frame Vehicle ID number (VIN) is on the front crossmember under the lower pulley. Every other ref I've seen here regarding placement of frame VIN's in on the side rails.
Old Jun 11, 2007 | 08:54 AM
merc546's Avatar
merc546
I've owned three 56's and all have been on the drivers post and attached with small phillips head screws.
Chuck
Old Jun 11, 2007 | 09:02 AM
fatfords's Avatar
fatfords
The data plate on my '56 F-100 was installed so that you could read it while standing outside the truck with the door open (top to bottom). It is attached with 4 phillips screws. I believe the placement to be original as the interior of my truck is still the original color.
I have not seen a '56 with the dataplate on the glovebox door, just 53-55's. I do agree that the frame stamping placement seems to be rather random and could be affected by assembly plant or maybe even assembly worker!
Good Luck!
Old Jun 11, 2007 | 09:11 AM
arctic y block's Avatar
arctic y block
F10D6R-11172
GVW 5000
WB 110
HP 120 @ 3900
TRANS 3-STD
CR RED 21 J 373
This is on drivers door. It is a 56 isn't it?
Old Jun 11, 2007 | 09:21 AM
fergusonicford
There are 4 mounting holes on the door pillar Driver's side which align perfectly with my Vin Plate.....looks like that is wheream going to mount it ...besides ;my custom dash does not have a glove box. I appreciate all of the input.
Old Jun 11, 2007 | 09:28 AM
NumberDummy
Chuck
Phillips head screws? Not rivets? Never seen any VIN attached with screws. It must have been an assembly plant specific, like San Jose built 56's with glove box door VIN's.
Old Jun 11, 2007 | 10:12 AM
9teen56f100
Mine are phillips head also.
Brian...
Old Jun 11, 2007 | 11:25 AM
fatfords's Avatar
fatfords
The 53 I had, the 54, 55 and 56 cabs I currently have, all have VIN plates attached with phillips head screws. Two were made in Dallas and the other two in KC. I don't remember ever seeing a VIN plate on the 53-56 attached with rivets.
Artic Y-Block,
F10D6R
F10-1/2 ton
D-223 6 cyl
6-1956
R-San Jose
Good Luck!
Old Jun 11, 2007 | 01:12 PM
NumberDummy
Artic Y-Block,
F10D6R
F10-1/2 ton
D-223 6 cyl
6-1956
R-San Jose
Good Luck!
R = San Jose is correct for 1956. Before 1956 = Richmond CA.
Old Jun 11, 2007 | 01:41 PM
bigwin56f100's Avatar
bigwin56f100
Just for the record the 56 big window I own is a R code San Hose built truck and it to has the vin on the drivers door jamb post attached with philips screws.
As I think about it all 6 of my 56's are in the same location and all of them are attached with phillips screws, and everyone of them were built at different plants.
Only my 53-55's had it on the glove box door.
To answer the original question the vin number should be read from top to bottom and be closest to the interrior.
Kevin Bigwin, 56's are my LIFE!
Old Jun 11, 2007 | 09:56 PM
arctic y block
Artic Y-Block,
F10D6R
F10-1/2 ton
D-223 6 cyl
6-1956
R-San Jose
Good Luck!
So the V8 Grill is definetly wrong. But still looks good.
