codes 65 and 54
Old Jun 10, 2007 | 02:31 PM
frederic.c01's Avatar
frederic.c01
codes 65 and 54
hi all.
can you help me on this one. My tranny has begun to go into fault mode after driving for a few miles. The O/D light flashes .
codes 65 and 54 with my odb.i rebuilt trany about 1000 miles.is a f350 dually with e4od.Trans temp is 250 °f after few miles with my airstream 23 ft.
thank's for yr concils.
fred
Old Jun 10, 2007 | 03:18 PM
topgunn's Avatar
topgunn
do you have a transcooler? My 92 F350 used up serval trans until I installed a gauge. I pull a 32' 5th wheel and found out from a radiator rebuider that the ford radiator trans cooler sometimes get pluged. Anything over 200 will burn your trans really quick. The torque converter might be damaged when you get that code.
Old Jun 12, 2007 | 01:05 AM
PLC7.3's Avatar
PLC7.3
65 is a good # .......but 54 is not.......
Have you ever reset the FIPL on the IP.
